Old 05-28-2010, 07:12 PM   #1
Uhgg's Avatar
Default Clutch problem
I have having troubles with my clutch on my Mach 427, I replaced the shoes and put a new clutch bell on and then ran it for about 6 tanks. Now all of a sudden the bell won't spin freely. I have tried shimming it, replaced the bearings and still can't get it to spin. The shoes and clutch aren't touching and I am at a loss as to what is locking it up, it spins freely until I tighten the screw down holding the c/b.
Any help would be greatly appreciated.
Thanks!
Uhgg
HPI Savage X 4.6, Losi LST XXL, Losi LST2, 1/16 Brushless Revo/Slash, Savage XL 5.9, HPI RS4 MT, Losi Mini LST2, Savage XS
Uhgg is offline   Reply With Quote
Old 05-28-2010, 07:25 PM   #2
littlelane's Avatar
you need to shim it out a little
kyosho strr
Power House Mods
Cold Fusion RC Products/Team Driver
littlelane is offline   Reply With Quote
Old 05-28-2010, 07:26 PM   #3
losi_racer's Avatar
Trader Rating: 25 (100%+)
Thanks!
if it spins freely before you screw the cb down you have to many shims in. take some out.if it still binding then are you using a washer or shim before you put the flywheel nut on? if so take that out too.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-28-2010, 07:27 PM   #4
Thanks!
Sounds like whatever your using as shims are putting pressure on the outer bearing when you tighten the screw.
Franchise is offline   Reply With Quote
Old 05-28-2010, 07:27 PM   #5
losi_racer's Avatar
that will add to the binding. i would say that if its binding before he tightened the bell down
Old 05-28-2010, 07:28 PM   #6
All4BSpinnin's Avatar
I had the same problem with my 427 it turned out to be the flywheel pins where the shoes sit were hitting on the clutch bell when tightened, shunning it should fix the problem though.
Savage X/Force .32/Swamp dawg tires/Boulder Holder body/Byron Fuels ( My toy)
Rustler/TRX 3.3/Traxxas/Integy/Byron Fuels ( The girlfriends toy )
All4BSpinnin is offline   Reply With Quote
Old 05-28-2010, 08:48 PM   #7
Uhgg's Avatar
I don't remember putting a washer behind the nut, the pins don't stick up through the shoes. Is the shaft supposed to come all the way or almost flush with the outer bearing in the c/b? There is close to a 1/16 of an inch gap from the end of the shaft to the outside edge of the bearing. Could this be causing the binding? If so any suggestions as to how to correct it?
Thanks for the replies so far.
Uhgg
Old 05-28-2010, 09:01 PM   #8
jsp619666's Avatar
I had the same problem with my Losi you need to get crank extender shims i believe ofna makes them they are the same diameter as your crank the go inside the front bearing and build up the crank so you can have more play on the bearings.
http://www.amainhobbies.com/product_...-Kit-3x49x03mm
Josh Peters
jsp619666 is offline   Reply With Quote
Old 05-29-2010, 10:03 AM   #9
Uhgg's Avatar
Figured it out. I took it all apart and found out that the clutch nut had backed out just enough to through everything out of wack. Tightened it up and all is well. Thanks for all the help.
Uhgg
buggy truggy clutch problem audik Nitro Off-Road 19 03-11-2009 12:41 PM
MTX4-R clutch problem? Spaza Australian Racing 13 12-12-2008 06:50 PM
Slipper clutch problem? BradT041 Monster Trucks 24 03-23-2007 09:08 AM
NTC3 and Evo 2 Sirio Clutch problem??? gentleman81 Nitro On-Road 9 08-26-2004 02:09 AM
Is this a clutch problem? albertlam Nitro On-Road 31 03-17-2003 08:18 AM
