Old 05-27-2010, 08:46 PM   #1
Default HELP!! Buggy won't start!!
About 3 weeks ago my buggy went WOT and then wouldn't start. I found out the "problem" was that the threads in the head button where the glow plug screws in was stripped.
I finally got a new head button today and the engine won't fire. It is turning over, though. I checked the glow plug and the ignitor. All checked out fine. I put brand new fuel in it and primed it (put my hand over exhaust) and it wouldn't start up.
I couldn't think of what it could be so I decided to set the needles about where they were on my stepdad's Savage when he got it: almost all the way open. I did that and was going to tune it once it fired but, yet again, it gave me hell.
I think I need a new engine.
Can anyone help?
Thanks,
Rob
supamagician is offline   Reply With Quote
Old 05-27-2010, 09:35 PM   #2
please help?
Old 05-27-2010, 09:51 PM   #3
RedlandRacing's Avatar
everytime i got a no start this is what i did.
1. open the glow plug, check the glow plug
2. pull the engine a few time; in case u flooded the engine.
3. install the glow plug
4. prime it nicely, i.e blow the exhaust tube.
5. put a few drops of nitro in your carb.
6. give it a try.
it always work for me... good luck.
MUGEN MBX6 M-SPec
ODONNELL Z01B
GO TECH
XCORERacing Servos
SPECTRUM DSM
RedlandRacing is offline   Reply With Quote
Old 05-27-2010, 10:00 PM   #4
The carb would be in the opening after removing the glow plug right? I did everything you said except put fuel into the carb and still nothing
Old 05-27-2010, 10:04 PM   #5
carb (crburator) is where your air filter attached to, remove the air filter n you'll see the opening...
MUGEN MBX6 M-SPec
ODONNELL Z01B
GO TECH
XCORERacing Servos
SPECTRUM DSM
Old 05-28-2010, 01:06 AM   #6
RUNNINONMT's Avatar
if the plug was loose and the motor went lean it could have damaged the motor. did your take the motor apart and inspect the internals?
RUNNINONMT is offline   Reply With Quote
Old 05-28-2010, 05:23 AM   #7
elkman's Avatar
Default LHS
Take it to your local hobby shop.
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 05-28-2010, 06:50 AM   #8
All4BSpinnin's Avatar
These are threads that irritate the hell out of me, if your glow plug and everything else are fine then 9 times out if 10 the problem is your TUNE! Come on people this is first week of owning a nitro stuff. Just because you tune your engine once doesn't mean it will hold that tune forever you need to stay on top of it, there are so many variables with a tune. THEY CHANGE FROM DAY TO DAY! And setting it the same as a savage engine will do nothing.. find the factory settings for the engine you're using and then set the engine to those settings.. this isn't brain surgery people.. there are like 10 posts like this every day, either use the search feature or give up and go electric.
/rant
Savage X/Force .32/Swamp dawg tires/Boulder Holder body/Byron Fuels ( My toy)
Rustler/TRX 3.3/Traxxas/Integy/Byron Fuels ( The girlfriends toy )
All4BSpinnin is offline   Reply With Quote
Old 05-28-2010, 11:07 AM   #9
Madbrad's Avatar
Trader Rating: 29 (100%+)
Is your ignitor charged ? Does it sound like its trying to start or does it osund liek your just turning over the motor?
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 05-28-2010, 12:06 PM   #10
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
That's the one that always gets me. But i figure it out quickly. My ignitor is awful so i got a new one. 35 bucks down the drain on the first one.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
My buggy won't idle, help please lethalsassonic Nitro Off-Road 12 08-18-2009 02:08 AM
Sportwerks Chaos won't start nlbum Nitro Off-Road 7 03-31-2009 09:32 AM
NEED HELP WITH CHAOS!! ENGINE WON'T START!!!RAWR! josher2468 Nitro Off-Road 10 01-01-2008 07:52 PM
