Old 05-27-2010, 09:14 AM   #1
Suspended
Angry TT EB4 question! please help
Hi,
I got pull start engine : PRO-21BX-R
I want to convert it to either Roto start or with my Starter box.
Can someone help me with what kind of back plate roto start i can put on that engine? Is it doable?
Since its a pull start, the engine is very high, so the starter box wheel does not work, I need to remove the pull start, then lower the engine, and i dont even know if that will work... Help is greatly appreciated.
Thank you,
XStarWake is offline   Reply With Quote
Old 05-27-2010, 02:18 PM   #2
Torian4000's Avatar
Trader Rating: 49 (100%+)
www.thundertiger4u.com
Call them and explain your situation.... I'm sure they'll have a new back plate for you and I assume you'll need shorter engine mounts to get the flywheel low enough to bump on a box.
Torian4000 is offline   Reply With Quote
Old 05-27-2010, 10:44 PM   #3
GRANPA 67's Avatar
Trader Rating: 32 (100%+)
Send a message via Yahoo to GRANPA 67
Cool
Originally Posted by XStarWake View Post
Hi,
Thank you,
I used to have an EB4(rtr) with the pullstart 21 mota, and broke the
pullcord,then decided to go with starterbox method, got a backplate
thru a hobby shop,had to grind a tad(.5-1mm)of the crankpin(which
locked into pullstart mechanism) and Yes, i also needed to lower the
mota for starter box method...good luck....
ASSOCIATED RC8B3 , NINJA B02 , HITEC, SANWA, AKA , DHAWK RACING
ASSOCIATED RC8T, NINJA B01A , HITEC, SANWA, AKA, PROLINE , AVID
LOSI 5IVE, ZENOAH 29cc, HITEC, SANWA, DDM, TEAM GONADS, TURTLE RACING
SHUT THE GATE ON THIS ONE , IT`S THE DUCK`S GUTS , IT SUCK`S NITRO..........
GRANPA 67 is offline   Reply With Quote
Old 05-28-2010, 06:18 AM   #4
I thought I posted this yesterday, You will need AN2035-1. That should be the back plate, you may need a new crank as well. to go roto start, just by the Tigerdrive system.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-28-2010, 12:33 PM   #5
Suspended
I see that the tigerdrive system is not that expensive... 40$ at the most and its a very good alternative. Thank you for the information!
For AN2035-1 , and a new crank, what should be the cost of that? it looks to me that its gonna a pain getting this beast on the box ...... expensive?
Thanks again all for the replys.
Old 05-28-2010, 12:47 PM   #6
not sure on the cost, maybe around 70-100 for the 2 parts, plus starter box
Old 05-28-2010, 05:33 PM   #7
Suspended
man... i already have the box, but i think 70-100$ for it to be box-ready is too expensive... Thanks a lot for the informations!
Ill go with the Tiger thing!
Peace
