Old 05-27-2010, 05:36 AM   #1
Send a message via MSN to helgso
Default Would these engines fit into a Losi LST?
Losi LST comes stock with the Mach .26 engine. I recently replaced it with a Mach 427 engine which fits perfectly. My question now is:
Would a LRP Z.28R Pullstart Spec.3,
ZR.30 Spec.2 Pullstart,
or even the Novarossi Plus 4C Team Ceramic Rear Bearing Buggy Engine fit the LST without modifications?
And even though the Novarossi engine is said to be a "buggy engine" would it fit?
Thanks!
Losi LST, Mach 427, JR servos
helgso is offline   Reply With Quote
Old 05-27-2010, 06:11 AM   #2
All4BSpinnin's Avatar
Yes, they will all fit but the buggy engine will not work because it is a bump start engine. You need something that is pull start or roto start.
Savage X/Force .32/Swamp dawg tires/Boulder Holder body/Byron Fuels ( My toy)
Rustler/TRX 3.3/Traxxas/Integy/Byron Fuels ( The girlfriends toy )
All4BSpinnin is offline   Reply With Quote
Old 05-27-2010, 06:21 AM   #3
I can buy a spinstartplate or a pullstart for tthe Novarossi engine and just replace them with the bump start, right? Or will I have to buy a special roto- or pullstart version of this Novarossi engine?
Old 05-27-2010, 06:25 AM   #4
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
The crankshaft is different on pullstart/rotostart engines. Real "race" (bumpstart) engines cannot be converted without changing the crankshaft.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-27-2010, 06:32 AM   #5
Alright, I understand now. But is there any limit for my LST? Can I just throw in any 1/8 scale offroad engine in there? Like a 0.45 engine or a bigger?
Old 05-27-2010, 06:48 AM   #6
DOMIT's Avatar
You'd actually want to ask the folks that manufacture or sell the engine. It depends on the case size and motor mount holes.
Old 05-27-2010, 07:02 AM   #7
What ever you can fit in there will work sort of..... Remember that these are designed for the amount of power put out by the engine they include so going to a more powerful engine may require replacement of the stock plastic gears in the tranny. You may want to replace them with Robinson steel gears. You would probley wanna stick with something that is pull start or roto start cause like Domit said, cranks are different and i would not put a RACE engine in my bash toy........
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-27-2010, 08:34 AM   #8
Thanks for the info.
Old 05-27-2010, 10:46 AM   #9
neobart's Avatar
Uhmmm what plastic gears?.......The LST transmision is though as nails as is, all metal.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 05-27-2010, 11:31 AM   #10
khudzik's Avatar
He probably meant the 2-speed plastic spur gears that you can replace with the Losi Ti-Ni gear set.
www.overdriverc.com
khudzik is offline   Reply With Quote
Lots of stuff for sale Squidward R/C Items: For Sale/Trade 58 06-27-2010 08:20 PM
