Old 05-26-2010, 11:19 PM   #1
Default How to identify clutch springs.
I purchased a clutch lot from a member on here but the clutch springs are all mixed together.
Anybody know which ones are stiffer/softer?
some of them seems longer on one end than others
They are associated springs for the rc8
funkhouser is offline   Reply With Quote
Old 05-26-2010, 11:24 PM   #2
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
Just take a calliper and measure them, if they're for the RC8, I'm guessing they'll range in the 0.9mm - 1.1mm range. The thinner, the weaker.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 05-26-2010, 11:32 PM   #3
ScottyM's Avatar
Trader Rating: 27 (100%+)
Measuring them is the only way to really know.. Anything else is at best a guess, and setting up a clutch needs more than guessing to get it right, or be able to copy it each time. If you don't have a 6" caliper for set up you need one.. You can get some cheap one online real cheap..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 05-26-2010, 11:35 PM   #4
I guess I have to go buy a caliper.
How would one measure it?
at the base of the coil?
Old 05-27-2010, 01:01 AM   #5
builtb16a's Avatar
i believe the thickness of the coil.. so the ends of the spring, not the size of the loop.
just like GA wire, 18ga, 16ga.. ect. its the size diameter of material, not how its twisted or built.
builtb16a is offline   Reply With Quote
Old 05-28-2010, 04:53 PM   #6
j_blaze14's Avatar
Trader Rating: 34 (100%+)
color, their 1.1's. silver for 1.0 and gold for .9.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
