Old 05-26-2010, 09:16 PM   #1
Default Is this normal? - Dynamite Mach 2 .21
I just broke in my Dynamite Mach 2 .21, and I have found that I can't even get it started unless I screw the low speed needle out 3 turns. This strikes me as odd, because the factory settings are 2.5 turns out. I thought factory settings were supposed to be rich? Do you think I have some kind of problem with my engine?
Losi 8ight
Nitro Rustler
Tamiya M04 - Karz #79
OFFroadrunner is offline   Reply With Quote
Old 05-26-2010, 09:20 PM   #2
Trader Rating: 12 (93%+)
Sounds like you have a really big idle gap to me. Get a pair of calipers or something and you want the opening on your car to be about .7mm-1.0mm. just make sure the open when the carb is shut is small. The smaller the hole the leaner you will run on the lsn.
rcdude236 is offline   Reply With Quote
Old 05-26-2010, 09:22 PM   #3
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
what was the weather like? cold? damp? could have been high bp..
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 06-06-2010, 09:09 PM   #4
I checked the idle, it was only about 1mm certainly no more. I went racing today I even tried closing the idle screw even more but to no avail. It is worth noting I can get a pretty decent tune on it when I do richen it out. Do you think that their factory settings are just off?
Losi 8ight
Nitro Rustler
Old 06-06-2010, 11:27 PM   #5
jmaxey51's Avatar
is that with or without the restrictor in? i made the same mistake when first starting, i did the idle gap with the restrictor in.
jmaxey51 is offline   Reply With Quote
Old 06-07-2010, 08:55 PM   #6
Thats less then 1mm with restrictor out.
Losi 8ight
Nitro Rustler
Old 06-08-2010, 11:29 AM   #7
Lille-bror's Avatar
Hi.
I've had an RB WS7II engine under my wings for a short period of time. I used my own homebrew, and before the first start, I set the needles as the manual suggested. The LSN was WAAAY too lean. Had to open it 1 turn, before I could prime and start the engine.
Otherwise it sounds like too lean HSN, issuse with the fuel line/tank, dirt in the carburator or an airleak.
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 06-09-2010, 12:01 AM   #8
Needle settings are just starting point they are nothing to live or die by.
There are too many things that can change it like car/truck, exh pipe, length of fuel line supply and pressure line, gearing, body, fuel, weather and the biggest thing how you drive it.
pdmustgt is offline   Reply With Quote
Old 06-09-2010, 02:46 AM   #9
Cappy's Avatar
Is that motor air tight ?
Tekno EB48.3 RX8 Gen2 T8 1900 19T..
Tekno ET48.3 RX8 Gen 3 T8 2000
Tekno |Sweep | Dialed Inc | Boca Bearings | Mels Shells
SLOW THE F%&# DOWN so you can go fast !!!
Cappy is offline   Reply With Quote
Old 07-11-2010, 10:05 AM   #10
I am using an O.S #8 plug, as was recommended by someone on these forums, but it is a little bit shorter than the stock one. Could that be causing problems and if so which plug would be a better choice?
Losi 8ight
Nitro Rustler
Old 07-11-2010, 10:12 AM   #11
Frank L's Avatar
Trader Rating: 148 (100%+)
Every engine will have different settings. When in doubt set it back to factory settings and retune. The biggest mistake I always make is wanting to touch the lsn before I get the hsn dialed in. That always results in a lean lsn and righ hsn. It has bitten me more than once. Just remember that the fuel flows through the hsn before it gets to the lsn so if the Jan is too rich then it will let too much gas into the lsn you might want to lean the lsn but don't leaning the hsn will lean the lsn too. Bottom line is set the hsn needle and then set the lsn.
Old 07-11-2010, 10:54 AM   #12
Cory Kerber's Avatar
I've found myself doing this alot lately. I pretty much try to tune my motor through the lsn, never really touching the hsn. And it results in a lean lsn like you said.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 07-11-2010, 02:15 PM   #13
So the #8 plug is alright, even though it is shorter?
Losi 8ight
Nitro Rustler
Old 07-11-2010, 02:19 PM   #14
yeah
Old 07-11-2010, 04:17 PM   #15
Trader Rating: 22 (100%+)
+1 Yea, the plug is fine. Dont worry to much about the needle settings. I have had engines before that they would not even start also with the " fatory" settings. AS long as it is running good and temps are ok. Its fine
heidmann1 is offline   Reply With Quote
Dynamite Mach 2 .21 question KrisB Nitro Off-Road 7 05-21-2010 03:26 PM
something for everyone! big_dog1893 R/C Items: For Sale/Trade 10 08-31-2008 12:31 PM
