Old 05-26-2010, 08:33 AM   #1
Send a message via Yahoo to 4flat_tires
Default n21b09/rt HELP, please look
I have a brand new n21b09 engine which is a rotostart. I can't seem to install it without having to remove the rotostart backplate because it hits the rear chassis brace. Now my question is if i decide to go bump-start, can i just leave the rotostart plate off with the OWB exposed or do i need to purchase a backplate cover? The OWB looks like a hex nut.
thanks
4flat_tires is offline   Reply With Quote
Old 05-26-2010, 08:45 AM   #2
thanks
just go bump start, its way better anyway. If you are going to use the roto start you need high engine mounts.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-26-2010, 08:54 AM   #3
Default thanks
If i go bump start, do i need to find a cover for the exposed OWB or do i just leave the back exposed?
thanks
Old 05-26-2010, 09:36 AM   #4
Yes, you will need to contract Nova and ask for the backplate for a N21 engine, I have searched and could not find one....
Old 05-26-2010, 09:50 AM   #5
Token,
Really appreciate the help.
Old 05-26-2010, 01:17 PM   #6
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
if going bump start proves a problem for whatever reason these would allow you to install it so the backplate clears the chassis.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=370314080160
place them between the engine mounting tabs and the engine mounts.
Edit: i should read these a little better before replying. i dont know if it would help with the spacing problem to the chassis brace. changing gearing to a larger spur and cb while maintaining the same ratio (spur teeth divided by cb teeth) to space the engine further out might help it a bit.
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 05-26-2010, 03:30 PM   #7
Default thanks bud!
Hey thanks for the reply looper. I think i'm just going to change to a different engine. It's just too much of a hassle to try to make this work. Just ordered a B5 .
Old 05-26-2010, 03:42 PM   #8
Madbrad's Avatar
Trader Rating: 29 (100%+)
Good choice on the motor, you wont be dissapointed with it.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
