Old 05-25-2010, 06:17 PM   #31
Trader Rating: 12 (93%+)
Originally Posted by RC-ZOMBIE View Post
Slightly thicker but not sticky or tacky, You really dont need sticky and tacky for a filter oil it just restricts air flo, dirt will stick to a lighter oil been doing it for yrs with no problems.
just my opinion. Sounds kinda scetchy to me. I just use air filter oil thats like 12.95 at my local dirt bike store, when i used to race we used it and now i use it on my rc and it will last me for many many many years.
rcdude236 is offline   Reply With Quote
Old 05-25-2010, 06:21 PM   #32
RC-ZOMBIE's Avatar
Originally Posted by fast11970 View Post
I race alot, hardly ever use the stuff, It may come in handy if you need to store a mill for months, I do use it if, I park a broke in mill, seems to be worth it, I get 8-10 gallons on a race engine, sometimes more, I have a GRP .21 that I began racing in Feburary of 2008, still running fine, it may have seen afterun oil once, I will be running this mill again this weekend. It currently has a screwed up clutch bell, cause my mounts came loose in the main(My stupid neglect) It has seen alot of fuel, Byrons gen II, Sidwinder, Torco, and White Lightning, still motering on, race on the Weekend, no fuel run out, no oil, fires up on demand.
I agree, if you race alot you don't need it. I use it the most when I store my engines for the winter
Associated~Tekno~Mugen
RC-ZOMBIE is offline   Reply With Quote
Old 05-25-2010, 06:24 PM   #33
RC-ZOMBIE's Avatar
I also use filter oil from my local motorcycle shop UNI filter oil is good stuff and Rock oil.
Old 05-25-2010, 06:25 PM   #34
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
See that is different. Storing for the winter or a long period of time I will use some ARO, but again I personally prefer the thinner variety.
As for air filters, you are correct that the thicker oils will attract more dust around the outside, but they will also better keep the fine dirt particles out. Solution to them loading up with dirt is to change your filter often. I use pre-oiled losi filters and change them often. Even the oil losi uses is a bit thin for an air filter oil IMO. And with that said, I would never put even that in my engine. Too thick.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-25-2010, 06:30 PM   #35
fast11970's Avatar
I use SWAFF, But I came from MX, UNI and Rock are Fine, If you want to choke your mill down, on the flip side, you will always be running rich, thats a good thing..just not a fast thing.
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 05-25-2010, 06:32 PM   #36
fast11970's Avatar
Use some grease on the ends too...
MBX6
Old 05-25-2010, 06:34 PM   #37
RC-ZOMBIE's Avatar
Rock oil is SWWAFF Other wise known as Synthetic water washable air filter fluid
Old 05-25-2010, 06:34 PM   #38
i use hobbico after run oil. Is this stuff bad? is it bad for my filled cranks? never thought to ask, but now i am starting to worry.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-25-2010, 06:35 PM   #39
i run my engine. probably 2-3 times a week i never using it. but i will use during the winter. When you use it in the winter do you just use it once and call it good for the winter?
Old 05-25-2010, 06:36 PM   #40
RC-ZOMBIE's Avatar
Not sure never used it call and ask them
Old 05-25-2010, 06:40 PM   #41
RC-ZOMBIE's Avatar
What I do and this is just me, is I tear the mill down and coat everything then put back together and shrink wrap it so no air gets in good to go!
Old 05-25-2010, 06:41 PM   #42
That is one of the ones I would personally consider "too thick". I don't know if it is safe on silicone filled cranks or not. If the silicone hasn't popped out of your ninjas yet, I would bet it is safe. Still wouldn't use it.
Yep once and you're good.
-Koby Kubrin-
Old 05-25-2010, 07:23 PM   #43
rcREALITY's Avatar
Trader Rating: 25 (100%+)
i only use after the race day is over. so when i get home and clean every thing up i put aro in my engine. i think it helps
rcREALITY is offline   Reply With Quote
Old 05-25-2010, 08:13 PM   #44
Thats what i used is the hobbico. I only used 2 drops at max. I dont seem to mind it. im gonna see if its ok, maybe i can read the back of it
Old 05-25-2010, 08:30 PM   #45
jnslprd's Avatar
i think hobbico is not safe for silicone weighed cranks.
jnslprd is offline   Reply With Quote
BAD AUSTRALIAN AMAIN FUEL KILLS ENGINES rc skyline Nitro Off-Road 215 11-18-2009 05:50 AM
Who uses Tribo Comm drops? Do you like them? JLMG1971 Electric On-Road 29 04-04-2005 04:29 PM
Electric vs Nitro pede Electric Off-Road 154 05-18-2004 08:20 PM
