Old 05-25-2010, 09:14 AM   #1
Default Cleaning & polishing engine parts
Hi Guys,
Wonder if you can help me.
I have always looked after my engines i tend to strip them down for inspection & clean all internals etc.
Then work on the Piston/Button Head etc.
I have always used the polish from JP Racing products.
It's come to the point where i have ran out & the Dist in the UK does not stock it anymore wont get any
What do you guys use if you do this method.
I know some of you are going to say dont do it etc but i have done this for many many years advised from some of the best European Onroad drivers over the few years its always worked treat for me.
My engines have always been going alot longer than some other peoples when they have just been left alone.
carlin is offline   Reply With Quote
Old 05-25-2010, 02:49 PM   #2
off road god's Avatar
I use Mother's wheel polish on my head buttons and aluminum pipes. Don't know about the piston....I just clean the internals with Simple Green and then use distilled alcohol.
WERKS RACING...PRO1RC...HEX CREW...BATTLEFIELD R/C...LOSI 2.0...JP PIPES...AKA,PROLINE TIRES...SPEKTRUM DX3R...JR SERVOS... PAUL CONWAY,TECHNICAL ADVISOR.
SAKURA ZERO S...NOVAK ELECTRONICS...MI SERVO...HPI PRODUCTS...FUTABA
off road god is offline   Reply With Quote
Old 05-25-2010, 02:51 PM   #3
on the piston head and head button i just use after run oil. Rub it with my finger and after a couple minutes it all comes off.
If you use aro like you should, and a good fuel with a good tune, there shouldn't be that much to clean off anyway.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-25-2010, 04:06 PM   #4
cdbias's Avatar
Use clean fuel to clean motors. It works wonders and keeps things lubricated. I also like to coat some of the internals with EB Mods after run oil.
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 05-25-2010, 04:11 PM   #5
blade954's Avatar
Trader Rating: 23 (100%+)
When i clean and inspect our OS engines i totally disassemble then use carby cleaner to blast away most of the carbon build up. The top of the piston i use a paddle pop stick to help remove the rest of the carbon. Once that is done i find it comes up like new. Same goes for the rest of the engine but i find the aresol can (carby cleaner Nulon brand) generally blasts the rest off easy. Once that's been done i blow down with compressed air a few drops of caster oil on the moving parts and a light coat all over and reassemble.
blade954 is offline   Reply With Quote
Old 05-25-2010, 04:24 PM   #6
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
why would you ever do that, CARBON is your friend ....dont ever clean that off...
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 05-25-2010, 04:40 PM   #7
it's not my friend when it's on my head button. The only part i don't clean is the deposits on the piston side or anything on the side of the piston.
Mugen
Old 05-25-2010, 05:29 PM   #8
mrbusta's Avatar
Trader Rating: 20 (100%+)
Send a message via MSN to mrbusta Send a message via Skype™ to mrbusta
carbon on the top is ok i would of thought for compression side of things
but the Nulon brand cleaner ok good as i use the same brand brak clean for the outside
SHAYNE/MONSTER ENERGY/BETA TYRES Australia
Thanks to www.wprcracing.com/P.N.D Paint works
81/MUGEN Mafia
RIP BUSTA BB ANGEL
mrbusta is offline   Reply With Quote
Old 05-26-2010, 12:57 AM   #9
pau_kacang's Avatar
here dirty style cleaning/service my murnan sirio xxx 1/10
1. diassemble the engine
2. clean using toothbrush & soap + water at internal & outside crankcase
3. clean using sponge & soap + water to clean piston, combution chamber, crankshaft, sleeve
4. using hairdryer to remove the water
5. assemble back & put some novarossi oil at all parts
i cleaning my engine every race. that engine still powerfull & already 1 half year. already apply this style to my sirio kanai evo 4
p/s : sorry for broken english
http://www.techmedia.com.my
pau_kacang is offline   Reply With Quote
