Old 05-26-2010, 11:16 AM   #16
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
about 2 years ago i had similar problems with my ninja tore it apart check everything was ok, great compression...but i did notice the button head didnt fit tight like it use to so i put a new GRP button head and no problems ..hope this help
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 05-26-2010, 11:25 AM   #17
Marcus Falconie's Avatar
Default +4c
Doug if it's a +4 C 2010 it is most likely done after 4-6 gallons. Every one I know that has run the C 2010 with the new rear bearing had problems at 4-6. Nova should have never changed the motor from the Origional +4 every one I know would get 10+ out of the first batch of +4's I know you know how to tune I race with you every week so I would just get another NINJA See ya Sunday, I hope you make it. I am just going to race Truggy because I have to pit for Ernest and most likely about 10 others : (
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 05-26-2010, 04:02 PM   #18
had a similar prob when i damaged the spray bar in the carb of a novarossi 3-port i barely overtightened the lowspeed when i was resetting it. i no it sounds crazy but it happen.
speedzone99 is offline   Reply With Quote
Old 05-26-2010, 04:16 PM   #19
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by losi_racer View Post
wtf frank? lol
I did what I usually do. I post before I finish reading your whole post and well then I have to go back and delete. So either way I get it.
Did you ever get it figured out?
Old 05-26-2010, 05:07 PM   #20
Trader Rating: 22 (100%+)
if it runs good for a couple minutes then starts acting up. it might just be worn out.... I have had engines that felt like they still had decent compression do the same thing and ended up needing a piston/sleeve. Sometimes even if it feels like it has ok compression it might not be enough.
5-6 gallons very well could be?
heidmann1 is offline   Reply With Quote
Old 05-26-2010, 07:55 PM   #21
i had almost the exact same problem. Except the screws i had in the cooling head were about half a MM to long. Caused all kinds of problems (long story).
I also had similar problems with a stretched/bent rod.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-26-2010, 09:32 PM   #22
It's your connecting rod. I'm guessing you never replaced it after break in? You need to change the con rod on Novas after they lose their mechanical pinch after break in. You should change your bearings while your changing the rod too.
400units is offline   Reply With Quote
Old 05-26-2010, 09:45 PM   #23
losi_racer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by helgso View Post
Even though you think your o-rings are ok, I suggest sealing the carb. A person on YouTube that calls himself Squirrel (his username is Squirrelod) says that even though the o-ring on the carb seems ok, he recommends removing it and sealing with gasket material.
You can find this video here: http://www.youtube.com/watch?v=6xwDy-I0Z4I
He mentions that some gasket material might not be strong enough. Get gasket material that can withstand over 350F for sealing with just in case.
EDIT: Notice that Squirrel also mentions Team Associated's green slime. It's used for sealing the HSN and LSN.
That guy... Nvm got getting into that one.
yup, see my next comment
i think so, i ran it hard for a good 15 min, white it was still hot, tore it out as fast as i could and felt the compression, its gone. I felt it in the car and it didnt feel great but enough where i didnt think it was the issue. Im prob sending it to alan burton to get a pinch, i ordered new bearings might as well use them. Im buying a new buggy in prob 2 weeks so i dont wanna have another 300 dollar bill on top of a buggy, right now anyway. I think i am moving away from novarossi tho, as marcus said, ive seen many issues with longevity, might go ninja in the buggy too if i can calm it down
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-26-2010, 09:46 PM   #24
Trader Rating: 12 (93%+)
How old is your fuel? I just had this problem went and bought new gas and the thing ran like a champ.
rcdude236 is offline   Reply With Quote
Old 05-26-2010, 09:53 PM   #25
99problems's Avatar
AIR LEAK!! Seal it then see what happens. Oh and check the fuel
Don't be a "CYBER BULLY" bring it to the TRACK!!
POINT and PULL!!
99problems is offline   Reply With Quote
Old 05-26-2010, 09:53 PM   #26
losi_racer's Avatar
as stated i tried new fuel too.
Old 05-26-2010, 09:53 PM   #27
losi_racer's Avatar
did you only read the first post?
Old 05-27-2010, 08:52 AM   #28
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
For the price... you can't beat the Alpha Plus engines (all 3 of them) and the Werks B5.
Be patient on break in with the Alpha... it will take a gallon or more... but it is worth it.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
Xray T1 David Galdo Electric On-Road 12705 07-04-2016 01:07 AM
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
2009 Hobbytown USA St. Charles Racing thunderbt3 Wisconsin & Illinois Racing 934 04-16-2010 09:05 AM
