Old 05-23-2010, 08:06 PM   #1
Trader Rating: 29 (94%+)
Default hot bodies help please
will kyosho front and rear drive shafts work in here tired of hot bodies breaking or falling out
kcpipeliner is offline   Reply With Quote
Old 05-23-2010, 08:08 PM   #2
Trader Rating: 12 (93%+)
How are you breaking them? Get the good WCE ones and they wont break on you!
rcdude236 is offline   Reply With Quote
Old 05-23-2010, 08:11 PM   #3
As Far as i know they dont. Do you have the updated thicker ones? If not, call hotbodies, send the shafts back and they will replace them for free with the new updated ones. if they still break then you need to invest in the WCE shafts
D8T_RACER is offline   Reply With Quote
Old 05-23-2010, 08:16 PM   #4
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
kyosho mp9 91mm axle somewhat fit but they bind up if you turn the wheel full lock at the full up stroke position of the suspension. for the price of the kyosho axles your better off with WCE they are much better material and will last 20x longer than stock.
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 05-23-2010, 08:38 PM   #5
jmaxey51's Avatar
i have a kit that is 2 years old that someone is letting me use and it still has the original shafts in it, he didnt run it hardly but still.... but i did snap one but it was because it popped out half way and twisted it but i highly recommend getting the WCE ones, they are almost indestructible
jmaxey51 is offline   Reply With Quote
Old 05-24-2010, 03:38 AM   #6
jammin32j's Avatar
+1 on the WCE shafts
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 05-24-2010, 03:49 AM   #7
wallot's Avatar
WCE shafts is all you need.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 05-24-2010, 06:24 AM   #8
LabRat99's Avatar
The Kyosho rears are a perfect fit in the front of the D8. They are a little long for the rear, there is a possibility that if you land badly on one wheel the shaft can bottom out in the cup.
LabRat99 is offline   Reply With Quote
Old 05-24-2010, 07:10 AM   #9
I am having trouble with the front to center and rear to center drive shafts
Old 05-24-2010, 07:18 AM   #10
underway's Avatar
Trader Rating: 48 (100%+)
Are the barrels worn out and need to be replaced when this snapping occurs? Where is snapping happening?
underway is offline   Reply With Quote
Old 05-24-2010, 09:35 AM   #11
LabRat99's Avatar
Oops. I misunderstood what you were asking. I don't think any Kyosho stuff will work unless it's MP9. I've heard but not verified that MBX6 center fronts fit, don't know about center-rear.
Old 05-24-2010, 11:29 AM   #12
offr0aden's Avatar
If you are running a D8?
This is what you are looking for -
HB67407 = 78mm = front center shaft
HB67408 = 105mm = rear center shaft
HB67405 = 91mm = f/r drive shafts
Hot bodies measures the shaft from the tip (Bone) to the end of the shaft not the CVD / ball.
I've personally never seen these pop out or just break - unless under bashing conditions. And even then, I've not seen a center shaft pop out.
Here's a tip - you can use the Lightning 2 pro drive axles in the D8 and they are much thicker and stronger then the first run of D8 axles. And they will sit 2mm deeper in the cups.
- Team -
"High Speed and Clean"
offr0aden is offline   Reply With Quote
Hot Bodies D8 Truggy Greg B Nitro Off-Road 10028 08-16-2017 05:44 PM
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
