Old 05-23-2010, 08:27 AM   #1
lewis666's Avatar
Send a message via MSN to lewis666
Default effects of changing rebound
i am slightly confused bout this rebound lark i currently have it with 100% rebound but what effect would i have if i put less rebound? help!
many thanks
lewis
Durango DEX410R, BCE Losi 8ight 1.5 (radical 621t), Durango DESC410R on the way!
radical engines- www.gotnitroonline.com
Got nitro team driver
lewis666 is offline   Reply With Quote
Old 05-23-2010, 09:04 AM   #2
SteveP's Avatar
It's probably better characterized as limiting the down travel, at least if I'm reading your question properly. Limiting the down travel of the suspension is a useful tool, but like any other tuning option, it can have positive effects in some situations and negative effects in others. I like to generalize suspension set-up in the following manner - for low-traction conditions, you want to set up the suspension so it's more soft, compliant, and with more travel and higher roll rates; for high-traction conditions you set-up the suspension more stiffly, rigid and with less suspension travel and less roll. If you're wanting more specific information, give us some more detail about the conditions you're facing and the way your car is reacting, good and bad, and then we'll have the info we need to get into the finer details.
SteveP is offline   Reply With Quote
Old 05-23-2010, 10:04 AM   #3
lewis666's Avatar
well my local track is very bumpy, covered in stones. it is very dusty covering a hard packed track. my car does not seem to like the straight at my track where because it is very bumpy and my cars suspension does not seem to absorb the little bumps. would reducing my rebound to 50%, maybe even 25% would this help?
Old 05-23-2010, 10:30 AM   #4
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
I always run zero rebound in my shocks, and it handles the rough great, and at high speed, it seems to keep my chassis stable ( instead of bouncy-looking ), and I'm still able to clear any jump with ease.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 05-23-2010, 10:33 AM   #5
lewis666's Avatar
thanks for the help i will try it and report back
many thanks
lewis
Old 05-23-2010, 10:39 AM   #6
Anytime..Best of luck!
Hpi Pro 4 Barry White Electric On-Road 16052 08-08-2017 02:05 PM
Hot Bodies Cyclone D4 EP buggy Mike Schumacher Electric Off-Road 1921 10-06-2014 11:33 AM
ALTOONA RACEWAY FORUM Ed237 Track Locator Forum 9108 06-28-2011 05:10 PM
Basic Tuning Info sad_rocc Rookie Zone 9 08-08-2007 12:58 PM
