Old 05-22-2010, 10:44 PM   #1
Default Werks racing clutch
Anyone running this clutch or have experience with it? I bought one to try. 2 Carbon shoes and 2 Teflon. Wondering if anyone had any suggestions.
devilsquid is offline   Reply With Quote
Old 05-23-2010, 01:07 AM   #2
Trader Rating: 22 (100%+)
Tighten nut to the suggested setting in the manual. Red loctite on the nut.
phixd is offline   Reply With Quote
Old 05-23-2010, 04:08 AM   #3
2fst2c's Avatar
Trader Rating: 114 (100%+)
Found some info here with a search..Was a lot more threads but these had the most info in them.
WERKS Clutch
werks clutch HELP!!!!
Werks racing clutch
2fst2c is offline   Reply With Quote
Old 05-23-2010, 05:29 AM   #4
Redvet79's Avatar
Look at this site good info. setup mine like it says and haven't messed with it for a gallon other than blowing it out with air gun.
http://www.twf8.ws/new/tech/options/...werclutch.html
Redvet79 is offline   Reply With Quote
Old 05-23-2010, 06:24 AM   #5
lowey79's Avatar
Best clutch in the business IMO! If you got the newer version that has the oring in the adjusting nut, then you almost don't need to loctite it! I've found the best setup in my 808 is carbon shoes, green spring and the adjuster nut 1/4 turn in from flush with the crank nut. This setup rips! I'm still on the original shoes that came with the clutch after at least 4 gallons of fuel and if you shim your clutch bell a little on the loose side, bearings will last for ages!!!
The works is a very solid clutch and once you take the time to set it up to your liking, it's pretty much a set and forget affair!
lowey79 is offline   Reply With Quote
Werks racing clutch vladconnery Nitro Off-Road 13 12-30-2008 06:38 PM
2 Werks racing clutch systems!! jldjlaudio R/C Items: For Sale/Trade 8 08-11-2008 05:18 AM
LRP .28 Spec 3, Jammin JP-3, Werks Racing Clutch Rob Banton R/C Items: For Sale/Trade 6 11-25-2007 07:42 AM
