Old 05-22-2010, 02:20 PM   #1
All4BSpinnin's Avatar
Default is this engine shot?
I bought a jammin jpx .21 off a member on here and just put it in my truggy today, me and my buddy then tried to get it running for 3 hours to no avail. Finally I took the head off and the piston has thick black "soot" all over it and I can turn the flywheel like the cranks not even connected to anything ( but it is obviously ) its that easy. We messed with the tuned and it still just sits there and cranks, doesn't even want to turn over. Also if you turn the flywheel up to like the middle of the cylinder it will slowly fall back down to bdc on its own or you can take it almost to tdc and just push the piston back down to bdc.
So is the engine garbage like I think it is? Was I ripped off like I think I was? (Engine was advertised to have 2 1/2 gallons through it)
Savage X/Force .32/Swamp dawg tires/Boulder Holder body/Byron Fuels ( My toy)
Rustler/TRX 3.3/Traxxas/Integy/Byron Fuels ( The girlfriends toy )
All4BSpinnin is offline   Reply With Quote
Old 05-22-2010, 02:27 PM   #2
sounds like you got ripped....no compression....dont buy used engines unless its form a buddy you race with.
absolutemayhem is offline   Reply With Quote
Old 05-22-2010, 02:31 PM   #3
That's what I figured, ill see if/when he emails me to see if he's going to make it right and if not ill be filing a claim with paypal.
Old 05-22-2010, 02:41 PM   #4
Ruune's Avatar
Send a message via ICQ to Ruune Send a message via AIM to Ruune Send a message via Yahoo to Ruune
you could probably buy a rebuild kit or just a sleeve. That should get you up and running.
Ruune is offline   Reply With Quote
Old 05-22-2010, 02:49 PM   #5
I'm not sinking more money into this junk engine when it was supposed to "run great"
Old 05-22-2010, 02:50 PM   #6
sickboy's Avatar
Trader Rating: 72 (100%+)
was the plug in or out when you were checking the compression?
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 05-22-2010, 03:00 PM   #7
Trader Rating: 47 (100%+)
Did you pull the glow plug and see if it glows when
connected to your ignitor? You didn't mention any-
thing about the combustion chamber being wet with
fuel. After spinning the engine over as much as you
have, the crankcase should be loaded with fuel and
should have been blowing out of the exhaust pipe also.
rageworks is offline   Reply With Quote
Old 05-22-2010, 03:08 PM   #8
I tried glow plug in and out, head on and off and it was blowing out the exhaust.(fuel that is) and yes the plug glows in the ignitor and I tried a new one.
Old 05-22-2010, 03:14 PM   #9
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
It sounded to me like it rolled over easy with the head off, well its supposed to do that. With the head on it just be harder...
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 05-22-2010, 03:30 PM   #10
if the glo plug is in and it rolls over that easy it is probably shot. What you should do then is break it down and see what the condition of the crank, rod, and bearings are. If the bearings have to much play and the rod to much slop and the crank pin is worn then it is shot.
In reality a motor is never fully "shot" unless the crank or rod is sticking out the side of the case.
however, being that it is a 200$ motor anyway it is not really worth it unless it needs a pinch on the sleeve a new rod and bearings. You could do that for about 80$
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-22-2010, 04:19 PM   #11
j_blaze14's Avatar
Trader Rating: 34 (100%+)
theres way too much that could be wrong, from simple to complex. if there is no compression at all it will at least fire for a minute or two. how is the carb? pulling fuel? if there is the smalles spec of dirt in the nipple it will not pull fuel in. if it is flooded then there is enough compression to pull fuel in and it should run. the black soot is normal, i think its called predetonation from too hot a plug or shims or something. i sold my jammin with 2 gallons on it a while back and its still got no play on the rod, full compression and 0 problems for several gallons now. i'm sure its something simple, tune maybe.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 05-22-2010, 08:08 PM   #12
We tried tuning for over an hour and when we first tried starting it it fired up and I gave it throttle and it died tried for a little more and it fired for about 5 seconds then after that it just didn't want to start at all, If I try to hold it sideways by the plug it just falls, I've never had an engine this easy to spin the flywheel with plug in..
Old 05-22-2010, 08:59 PM   #13
what do you mean hold it sideways "by the plug"?
did you mean flywheel? If so, the flop test really means nothing.
Mugen
Old 05-22-2010, 09:28 PM   #14
D8
D8's Avatar
pull the piston and sleeve out and if the piston goes thru the sleeve all the way and it comes out the top then your sleeve needs a pinch or a new one.
Main Sponsor- My Wallet....
Mugen MBX7/Werks B5/M11
GS CLX PRO/Werks B2/M11
Sidewiinder Fuel
D8 is offline   Reply With Quote
Old 05-24-2010, 12:38 AM   #15
You sure you not spinning it backwards
pdmustgt is offline   Reply With Quote
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
Is my engine shot? T$ Nitro Off-Road 14 09-14-2008 07:50 PM
What engine is this?? boogernissan Nitro Off-Road 8 08-30-2008 09:40 PM
Electric engine overheats and desolders wires. Why? Jynx Electric Off-Road 9 10-17-2007 09:42 PM
