Old 05-21-2010, 07:28 PM   #1
Default Setting up shock rebound?
How do I limit my shock rebound? And what other things can I do besides changing pistons, fluid, or springs to tune my shocks?
bevofrancis is offline   Reply With Quote
Old 05-21-2010, 07:31 PM   #2
jjshbetz11's Avatar
With the amount of fluid in the shocks. mJust be carefull to not rip your shock blatters.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
jjshbetz11 is offline   Reply With Quote
Old 05-21-2010, 07:42 PM   #3
How about some tips on how to do it, or a link or something that talks about it?
Old 05-21-2010, 08:23 PM   #4
tc5 man's Avatar
and it takes quite a bit of time to get it were you want it lol, and not to metion you dont know if theres, a couple of air bubbles ethier from doing it.
it takes patience !
Old 05-22-2010, 06:11 AM   #5
2fst2c's Avatar
Trader Rating: 114 (100%+)
http://www.youtube.com/results?searc...ock+setup&aq=7
All sorts of videos on shocks here!
2fst2c is offline   Reply With Quote
Old 05-22-2010, 06:22 AM   #6
Akhor's Avatar
The easiest way to do this is to first figure out the amount of rebound you want. ie 25%, 50% etc. Once you know this, find out then length of your shocks and how many mm the shock needs to compress to reach this about of rebound.
Then go and cut a piece of fuel tubing this length, as well as add a long cut up the side of the tubing so it opens wide.
Once your shock is at the stage where it's ready to be bleed, simpily put on this piece of fuel tubing and slide the shock shaft up so that the tubing is the spacer between the top and bottom of the shock shaft.
This will bleed make bleeding the left and right shock to the exact same rebound very simple.
Remember, some models of vehicles have different shock length on front vs back so if your running 50% rebound all around on your vehicle, you will need one spacer for the front and a different spacer for the rear.
Hope this helps.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 05-22-2010, 08:00 AM   #7
tc5 man's Avatar
Hope this helps.
on a 1/8 buggy/truggy or a 1/10 you talking about ? i know you use a spacer or fuel tubing on a 1/10 on the front shocks.
Old 05-22-2010, 08:43 AM   #8
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
I don't think that he means to keep the spacer there, it's just a temporary removable spacer that you make to get the rebound even from left to right( basically, it allows you to push the shock shaft back into the shock body evenly on the left and right shock--great idea )
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 05-22-2010, 08:49 AM   #9
tc5 man's Avatar
yea that makes sense if you use, them though i know you whould have to take out the droop screws though.
Old 05-22-2010, 08:59 AM   #10
you only use it when building your shocks, and then you remove it from the shaft after you've rebuilt the shock ( that is why you make the cut along the length of the tubing. ) Basically it's just a removable spacer that makes it easier to have the same rebound on your shocks from left to right..it doesn't stay on the shocks.
..I think that you're thinking of up-travel limiters in the form of tubing on the shock shaft to prevent the shock from fully compressing..totally different thing though.
Old 05-22-2010, 09:05 AM   #11
Zerodefect's Avatar
Download Xray's 808 manual from Xray's website. Pretty good shock building instructions. Should work with most 1/8th scale kits.
I never go past 25% rebound. Usualy I use less, only 1/4". I like very little hydraulic rebound in my shocks. It just makes the car floaty and wears the bladders quicker.
Zerodefect is offline   Reply With Quote
Old 05-22-2010, 06:45 PM   #12
Akhor's Avatar
I'm talking about 1/8th scale.
It's just a temporary spacer so that you can get both the same. You remove it once you have installed the shock cap. Since this spacer is on the outside between the bottom of the metal shock body and the top of the plastic eyelet.
--Blaine--
VBC D07, VBC D08
Old 05-23-2010, 07:04 AM   #13
Madbrad's Avatar
Trader Rating: 29 (100%+)
What does adding rebound to the shocks do ?
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 05-23-2010, 08:36 AM   #14
Joey Powell's Avatar
It makes the shock compression resistance increase progressively, particullarly toward the end of the stroke. To me it feels bouncy most of the time, but it can be a good thing to prevent hard chassis slapping.
Phin Design R/C (phindesignrc@gmail.com)---VP-Pro-USA---Maxy's Fuel & Engines---TKO Competition Development---
"There are no problems, only solutions."
Joey Powell is offline   Reply With Quote
Old 05-23-2010, 10:31 AM   #15
tc5 man's Avatar
oh ok i know what your taking about now.
Setting up my E-revo Slow_and_Low Monster Trucks 10 04-11-2010 10:43 PM
shock pre-loading jrwoodchuck Nitro Off-Road 16 10-06-2008 06:36 PM
Shock Rebound John_Stones Electric On-Road 7 03-20-2005 06:08 PM
Setting problems.. ijnek Malaysian R/C Racers 47 10-31-2002 04:59 AM
