Old 05-23-2010, 10:52 AM   #16
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
Originally Posted by Madbrad View Post
What does adding rebound to the shocks do ?
With rebound built in: when you have the springs off the shocks, and you compress the piston into the shock body and release it, it will push itself back out, depending on how much rebound you build into the shock..this give you more 'pop' of of jumps.
Zero rebound has a neutral feel but may lack the pop that some are after. It all depends on what you like and the track you run on.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 09-22-2011, 07:16 AM   #17
Jammin#2's Avatar
Glad i found this, I'v been wondering what rebound is for some time now. I'v always built my shocks with 100% rebound cuz i thought that was how it was supposed to be.
RELAX!!! It's a toy car race!
The TRACK @ Harbor Hobbies https://www.facebook.com/pages/The-Track-at-Harbor-Hobbies/125266694216753?sk=timeline
Team Associated RC8.2, RC8BE, SC10RS, TC5M, B5M, TC5R, B44.3
Jammin X1CR FTE, Corraly RDX Phi 09, 3Racing F1-09
Jammin#2 is offline   Reply With Quote
Old 09-22-2011, 11:18 AM   #18
tc5 man's Avatar
I try to use full rebound on my shocks on my truggy because if you try to set it at less rebound, theres a chance you will get air bubbles inside the shock . I run it like that on every track i go to.
And running full rebound i did notice no extra air gets inside the shock.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 09-22-2011, 11:30 AM   #19
Limywidget's Avatar
Originally Posted by Akhor View Post
The easiest way to do this is to first figure out the amount of rebound you want. ie 25%, 50% etc. Once you know this, find out then length of your shocks and how many mm the shock needs to compress to reach this about of rebound.
Then go and cut a piece of fuel tubing this length, as well as add a long cut up the side of the tubing so it opens wide.
Once your shock is at the stage where it's ready to be bleed, simpily put on this piece of fuel tubing and slide the shock shaft up so that the tubing is the spacer between the top and bottom of the shock shaft.
This will bleed make bleeding the left and right shock to the exact same rebound very simple.
Remember, some models of vehicles have different shock length on front vs back so if your running 50% rebound all around on your vehicle, you will need one spacer for the front and a different spacer for the rear.
Hope this helps.
Nice tip. I added rebound the other night and had a fit getting them set the same. Next time will be easier.
www.ROCCKracing.com
Bacon is meat candy without the fussy wrapper...
"Equations are the Devil's sentences." - Colbert
OODA loop: Observe-Overreact-Destroy-Apologize
Limywidget is offline   Reply With Quote
Setting up my E-revo Slow_and_Low Monster Trucks 10 04-11-2010 10:43 PM
shock pre-loading jrwoodchuck Nitro Off-Road 16 10-06-2008 06:36 PM
Shock Rebound John_Stones Electric On-Road 7 03-20-2005 06:08 PM
Setting problems.. ijnek Malaysian R/C Racers 47 10-31-2002 04:59 AM
