Old 05-21-2010, 03:34 PM   #1
Default odonnell ss21 wont start
i just recently got the odonnell buggy and motor.. just got it all together and the motor doesnt wanna turn over at all.. i can turn it over by hand but its very very hard .. any suggestions?
buellboy1200 is offline   Reply With Quote
Old 05-21-2010, 03:45 PM   #2
ya hit it with heat gun while its sitting on the box. there isnt many motors that you will be able to turn over by hand when they are new.
also just follow the instructions for breaking it in
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 05-21-2010, 04:09 PM   #3
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
wrap a 10 scale tire foam around it when u break in
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 05-21-2010, 04:10 PM   #4
RedlandRacing's Avatar
i turn the flywheel with a flat screwdriver because i dont hv a heat gun...not sure good or bad though in long term...
MUGEN MBX6 M-SPec
ODONNELL Z01B
GO TECH
XCORERacing Servos
SPECTRUM DSM
RedlandRacing is offline   Reply With Quote
Old 05-21-2010, 04:13 PM   #5
jmaxey51's Avatar
i dont have a heat gun either but a hair drier gets the job done, i can get my engines heated up to about 180-200 degrees.
jmaxey51 is offline   Reply With Quote
Old 05-21-2010, 04:22 PM   #6
i wish my gf hairdryer is cordless... .
MUGEN MBX6 M-SPec
ODONNELL Z01B
GO TECH
XCORERacing Servos
SPECTRUM DSM
Old 05-21-2010, 04:32 PM   #7
Stubbs's Avatar
Trader Rating: 57 (100%+)
Do a search for Competition Heat.....it's the best money you'll spend, and your motor will thank you for it.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 05-21-2010, 04:35 PM   #8
i had the thing up to 200 .. still no go
Old 05-21-2010, 04:52 PM   #9
Stubbs's Avatar
What starter box are you using? I've got the blue top Ofna....the one that you can almost start a small block Chevy with, and I had a little difficulty when I was first starting my motor.
You're likely just getting the top of the head to 200 deg., not fully saturating everything to get it to expand. Try a lower heat setting, but leave it on the motor longer. Once everything expands, it'll be easier to start.
Like I said though, look at Competition Heat. I haven't used my heat gun once since I bought my heater from Eric...good product.
Old 05-21-2010, 05:17 PM   #10
Trader Rating: 43 (100%+)
When they are new I have had them get stuck at tdc, turn the flywheel with a screwdriver to get it loose and be sure its at bdc and heated up before you try to start it again. The flywheel does spin freely up until it gets to tdc doesnt it?
www.coyotehobbies.com-Owner
Brian Alderman is offline   Reply With Quote
Old 05-21-2010, 05:20 PM   #11
Stubbs's Avatar
Good point. I was assuming that it did....if not, you've got something bad going on.
Old 05-21-2010, 05:25 PM   #12
Old 05-21-2010, 05:34 PM   #13
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Mine was the same way, get it warm, and make sure your starter box battery is in tip top shape (charged)
It will go, just takes a bit to break in a motor.
Why is this hobby so full of drama? Its toy cars....
Dlewis4 is offline   Reply With Quote
Old 05-21-2010, 06:04 PM   #14
jmaxey51's Avatar
are you using a losi starter box?? i have heard people not having fun with break in with the losi box, or atleast the order ones.
Old 05-21-2010, 07:52 PM   #15
So I finnally got it started I had it running for about a min and pulled the glow igniter off and it died. And I haven't got it started yet. As for the starter box it's a cheap one. I didn't think it made a huge differance with what one you got. I probably should get a good one. Ne ideas?? And my motor does turn really hard at tdc
