Old 05-21-2010, 06:14 AM   #1
RedlandRacing's Avatar
Default DIY clutch tool
Installing the clutch cld be a bitch without clutch tool, almost impossible to install 1.1mm spring clutch using screwdrivers. if you dont hv clutch tool, can use this small t nut tool that fit nicely on the spindle, make a groove using dremel tool. catch the spring on the groove n twist it... then push it down.
MUGEN MBX6 M-SPec
ODONNELL Z01B
GO TECH
XCORERacing Servos
SPECTRUM DSM
RedlandRacing is offline   Reply With Quote
Tags
clutch, diy
