Old 05-19-2010, 03:25 PM   #1
trevor15308's Avatar
Send a message via Yahoo to trevor15308
Default motor problem
i have a jammin jpx .21 engine and the carb has been getting stuck on half throttle. i founf that the carb slide fells gritty when u pull the throttle so i cleaned it and its a little better but how do you guys fix this
AGAMA RACING-TKO BEARINGS-AIRTRONICS-SIDEWINDER-WERKS-PROLINE-VP PRO USA-RCrenew.com
trevor15308 is offline   Reply With Quote
Old 05-19-2010, 04:46 PM   #2
Trader Rating: 12 (93%+)
Some of it could be the angle and the way your carb is set. Sometimes the linkage doesnt push it all the way back in. Make sure you set it up right.
rcdude236 is offline   Reply With Quote
Old 05-19-2010, 05:15 PM   #3
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Make sure that the line on top of the carb, is lined up with the notch inside the carb. if not, its not the exact size of the circle so it wont go in and out just right.
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 05-20-2010, 12:51 AM   #4
Trader Rating: 21 (100%+)
take the carb out of the engine, take the carb boot off and clean it with denatured alcohol, put the boot back on and install the carb on the engine without tightening the pinch bolt align the carb so that the linkage can pull it straight and not at an angle. You can move the ball link (where the linkage connects to the carb) around for a better position. Once everything is aligned the tighten the pinch bolt.
TopGearRC is offline   Reply With Quote
Weird Motor problem.. smokinu Nitro Off-Road 35 10-14-2009 11:20 PM
Axial .28 MOTOR PROBLEM monkman409 Nitro Off-Road 13 03-25-2009 10:17 PM
Motor problem with B4 Jeff K. Electric Off-Road 10 07-30-2007 11:35 PM
Epic stock motor problem S15Racer Electric On-Road 10 08-31-2004 11:51 AM
Krypton motor problem. rcpilot Electric On-Road 30 07-09-2003 12:05 PM
