Old 05-19-2010, 08:05 AM   #1
jeff_ellis_9's Avatar
Default how do I fix this?
this is on the rear of my Losi 8ight. I noticed it when I dis-assembled for cleaning. The drive cup on this one side (right side) has abnormal play in it. It moves all around but mostly up and down.
whats wrong and how do I fix it? I have never torn down a diff. what do I need to get? thanks!
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 05-19-2010, 08:18 AM   #2
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
How old is your buggy?
That could be several things... I'll list them in the order I expect to be most likely.
1) Bearing on the differential. To fix it, replace the bearing.
2) Plastic insert that supports the bearing. See the thread about racing a RTR that came up today... it explains about a metal replacement for that. (I THINK that is the right side, but I honestly don't remember... it only has those on one side.)
3) There could be wear where the outdrive goes into the diff. Replace whatever part is worn. Note that it may require more than one part be replaced, ESPECIALLY if it was ran without diff fluid... which is possible if you have never done you diffs. It CAN leak out... especially if the o-rings are old. Running a diff dry will mess them up.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-19-2010, 08:21 AM   #3
Its the bearings or a really wore down plastic holder
I would rebuild the whole thing.
New bulk head
alum bearing holders - see your other topic for part number
new bearings, I use Avid and Protec dollar bearings...
I would tear the whole rear apart.....
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-19-2010, 08:24 AM   #4
DOMIT's Avatar
New bulk head
+1...
and add to that new o-rings and differential gasket.
And if one bearing is that bad, you should replace them all. Every bearing on the car.
Old 05-19-2010, 08:38 AM   #5
Originally Posted by DOMIT View Post
+1...
thats what I would do..... Thank god for dollar bearings
Old 05-19-2010, 08:41 AM   #6
what o rings?
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-19-2010, 08:47 AM   #7
DOMIT's Avatar
what o rings?
They go inside the diff around the shaft of the outdrives... there is one on each end. The rubber gets dry and hard, and then the diff fluid leaks out.
Do all 3 diffs. And ask one of the Losi guys to help you with fluid selection. (I used to run 5k in all 3 diffs and liked it... it tamed the car down... but others will not agree with that selection!) Clean all the old grease out of the diffs and use good fluid. (Losi stuff is fine, but so is associated/AE, mugen, PTRC, etc...)
Old 05-19-2010, 08:54 AM   #8
http://www.losi.com/ProdInfo/Files/8...e-10-04-06.pdf
lol, im still not seeing it. I do see the part number A3505 rings. Is that it? It is the gaskets right?
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-19-2010, 09:04 AM   #9
DOMIT's Avatar
LOSA3505 appears (from the exploded view) to include both the paper gasket and a pair of o-rings. I'm not a Losi guy, haven't had one for a long time... but I THINK that is it.
You should buy several of those... enough to do the car, and a couple spare sets.
Old 05-19-2010, 09:06 AM   #10
DOMIT's Avatar
p.s. Don't waste your money buying Losi's bearings. They're not that great... overpriced for what you get. Buy the $1/each bearings from Avid, Ready Rollers, etc... (you need to figure out how many you need of what size...) They're every bit as good if not better, for a lot less money.
Old 05-19-2010, 09:14 AM   #11
I believe this set will do the entire buggy, right?
each diff gets two rings and one gasket.....?
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-19-2010, 09:24 AM   #12
yes
Old 05-19-2010, 09:31 AM   #13
so being that the gears are fine. this is what all I will need for a rebuild of the entire buggy:
(1) seal set
(6) 8x14x4 flanged bearings
(1) alum gearbox bearing inserts
couple more questions:
will I need outdrive cups?
you said a bulkhead, do you mean the gearbox? will I really need that?
and what fluid do I use? and im kinda confused on this, somebody said in another post that the 1.0 uses grease, not fluid. which is it and what do I need to get?
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-19-2010, 09:33 AM   #14
Trader Rating: 96 (100%+)
Just start removing screws and figure out how everything works.
I see these posts all of the time, and it'll take less time to figure it out on your own than to post questions and wait for answers.
K.Copeland is offline   Reply With Quote
Old 05-19-2010, 09:44 AM   #15
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
+1
Take pics...and then get the tools out and tear it down taking as many pics as you think you might need to re-assemble it when you're done. After the first tear down/rebuild...you won't need to take pics anymore ;-)
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
How do I fix and air leak by the carb? kcsoa22 Monster Trucks 6 09-01-2005 07:01 PM
How do i fix my glitch on my helios??? HELP EngTat Electric On-Road 12 12-11-2004 07:58 PM
