Old 05-19-2010, 09:49 AM   #16
Originally Posted by jeff_ellis_9 View Post
so being that the gears are fine. this is what all I will need for a rebuild of the entire buggy:
(1) seal set
(6) 8x14x4 flanged bearings
(1) alum gearbox bearing inserts
couple more questions:
will I need outdrive cups?
you said a bulkhead, do you mean the gearbox? will I really need that?
and what fluid do I use? and im kinda confused on this, somebody said in another post that the 1.0 uses grease, not fluid. which is it and what do I need to get?
I would strongly recommend the gearbox... you should not need the cups unless they really look bad.
here is the link to losi. this has all the manuals and setup sheets for the buggy.
http://www.losi.com/Products/Support...rodID=LOSK0800
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-19-2010, 10:14 AM   #17
jeff_ellis_9's Avatar
hmmm, I wonder something. Here I found a gear box set for the rear, it says 2.0 buggy/truggy, but it says it also replaces the original (losa4428) gear box. BUT, this set comes WITH the bearing inserts you guys were talking about. Would the ones in this set be plastic or would they be the aluminum ones?
http://cgi.ebay.com/LOSI-LOSA4450-RE...item5ad8abb31a
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 05-19-2010, 10:26 AM   #18
they are the plastic ones for the 2.0.... all alum parts are sold separate
Old 05-19-2010, 10:42 AM   #19
ok. thanks. I gotta get this stuff ordered so I can do my rebuild.
As far as just normal wear, how can you tell when your diff bearings are worn out? as well as center diff bearings? Or once a couple go out, just replace all?
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-19-2010, 12:42 PM   #20
Madbrad's Avatar
Trader Rating: 29 (100%+)
You can find out the hard way like i did last weekend. The rear diff bearings lock up and the friction from the drive shaft melted the housing. I lost power to the rear diff and only had power to the front.
To check a bearing its best to take them out and rotate them with your fingers. At the same time you looking for any spots that are not smooth. If it feels like its catching on a spot then replace it.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 05-19-2010, 12:51 PM   #21
Tear it down and check each bearing by hand, if they are not smooth, replace..
get the little blue alu bearing holder for the center diff also
http://www.losi.com/Products/Feature...rodId=LOSA4442
Old 05-20-2010, 05:47 AM   #22
cool. so pretty much I would have to take diff's off, empty fluid, check bearings, replace if needed?
So about how often is it good to check?
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-20-2010, 06:04 AM   #23
After every race or two. Dude I personally spend alot of time wrenchin. After last season, I learned my lesson with DNFs and I hate when its a user made mechanical issue. So I try to rebuild the whole car after each race or right before a big race.
Old 05-20-2010, 07:04 AM   #24
i just noticed this as well not to long ago. My front bulkhead has no play what so ever. The rear one has a slight tick of play in it. I just rebuilt but before there pretty good play on most of the outdrives. I know it's the bulkhead seeing as i have replaced most of the bearings.
I for one think it is almost impossible to get all the play out of everything. So how much is ok for these out drives? I have very little but you can still feel it when you move the outdrive back and forth.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-20-2010, 07:46 AM   #25
just checked them again. they are all pretty tight but one. It has some play in it, but how much is bad? It's not that bad, not like the OP.
any reassurance would be great.
Mugen
Old 05-20-2010, 10:25 AM   #26
yea mine are pretty bad. So bad it actually moves the axle some. In the pic I posted, where I circled is a small metal ring (thin) thats coming off from the diff and sliding down the drive cup. Pretty sure thats not supposed to be there. Im just going to tear it all down and rebuild them, put in the alum upgrade bearing holder and be done with it.
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-20-2010, 10:48 AM   #27
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
That's probably part of the bearing. lol
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-20-2010, 10:46 PM   #28
I was meaning to ask, I guess mostly to "Token", but anybody please answer if you know why.
But why do you strongly recommend buying a new bulkhead (gearbox)?? Please specify what could be wrong with the one I have?? I was just totaling up everything and for the complete rebuild, the gearboxes are the most expensive parts. thanks
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-20-2010, 10:53 PM   #29
jmaxey51's Avatar
driving it with something worn out ruins everything attached to it. it sucks but thats racing for ya. i check everything out everytime i run my stuff. i have never had a DNF except for two times one was because of a 10 dollar servo went after 5-6 months of use and the other was because of a glow plug and not having another one to put in. if something is loose/worn a little replace it ASAP or you can end up spending a 100 dollars versus 10-15 bucks. been there done that.
jmaxey51 is offline   Reply With Quote
Old 05-22-2010, 07:27 PM   #30
Oh before I order everything, I can't tell by the losi.com manual, but how many of these bearing holders do I need for the center? All I can see on the parts manual on one, the picture hides weather or not I need one on the other side as well.
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
How do I fix and air leak by the carb? kcsoa22 Monster Trucks 6 09-01-2005 07:01 PM
How do i fix my glitch on my helios??? HELP EngTat Electric On-Road 12 12-11-2004 07:58 PM
