Old 05-16-2010, 08:13 PM   #1
Uhgg's Avatar
Default Mach 427 piston sticking
My brother in law is having trouble with his piston in a mach 427 sticking just after it starts the compression. He has it out and I was looking at it and it doesn't look like it is binding or anything, the bearings feel good, and everything looks right. The motor isn't very old and has had great compression. He said he was running it and it stuck while driving. We have tried lubing it with fuel and after run oil but it still sticks just as soon as it passes the ports and seals off the bottom of the cylinder.
Anyone have any suggestions of what to check or how to fix this before we tear it all apart.
Thanks, Uhgg
Uhgg
HPI Savage X 4.6, Losi LST XXL, Losi LST2, 1/16 Brushless Revo/Slash, Savage XL 5.9, HPI RS4 MT, Losi Mini LST2, Savage XS
Uhgg is offline   Reply With Quote
Old 05-16-2010, 08:54 PM   #2
Chill_Will's Avatar
Trader Rating: 32 (100%+)
How much fuel has he ran through it?
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 05-17-2010, 09:19 AM   #3
Uhgg's Avatar
Not 100% sure, he bought it used (Ebay). From looking at the car and comparing it to my muggy, that has seen almost 2 gallons, I don't think it has seen much fuel. I am thinking he has ran maybe 8 tanks thru it since he got it. The person he bought it from bought it from someone else as well and only drove it up and down his driveway once.
Uhgg
Old 05-17-2010, 09:58 AM   #4
Cappy's Avatar
Trader Rating: 14 (100%+)
Thanks, Uhgg
Im wondering if that sleeve has been repinched too tight
Tekno EB48.3 RX8 Gen2 T8 1900 19T..
Tekno ET48.3 RX8 Gen 3 T8 2000
Tekno |Sweep | Dialed Inc | Boca Bearings | Mels Shells
SLOW THE F%&# DOWN so you can go fast !!!
Cappy is offline   Reply With Quote
Old 05-17-2010, 11:07 AM   #5
Uhgg's Avatar
It ran fine for the 8 or so tanks he has ran thru it. He hasn't had it repinched or anything. He told me he was running it, stopped and refueled and then started it up and it stuck at TDC. He showed me the motor and it doesn't get anywhere near TDC before it sticks, you have to physically push it down while turning the flywheel to get it to release, otherwise the shaft turns in the piston arm.
Uhgg
Old 05-17-2010, 11:12 AM   #6
open it and take a close look, maybe the rod is bent
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
