Old 05-15-2010, 04:06 PM   #1
Garet Jax's Avatar
Trader Rating: 91 (100%+)
Default Engine Killing Glow Plugs
Hello all,
As long as the glow plug has the ignitor on it, then the engine runs great. Almost immediately when I take it off, the engine stalls.
I replaced the glow plug and it ran great for a minute or two. Then it started running only when the ignitor is on the glow plug. Do I have something inside the engine damaging the glow plug or is it something else?
Do I rinse the engine out with gas or do I try something else?
Thanks.
I am not a "Tech Master" nor even close. I simply have a lot of posts. If you want some sage advice, the only that I can give is don't listen to me.
Garet Jax is offline   Reply With Quote
Old 05-15-2010, 04:11 PM   #2
helivaguy's Avatar
Trader Rating: 42 (100%+)
prob lsn is very rich,lean it a bit or you can try a hotter plug if it does not help.
also a bad rod/worn crankpin or rear bearing are known to kill glowplugs.
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
Old 05-16-2010, 06:19 AM   #3
Garet Jax's Avatar
Hhhmm.
Could it be as simple as the rich tune dousing the glow plug and extinguishing it?
Old 05-16-2010, 08:03 AM   #4
captain america's Avatar
What does the glow plug filament look like? Is it shiny, dull grey, or does it look corroded with dark spots? While it could very well be too rich at the bottom, it could also be that your engine is set too lean and burning your plugs. The situation you describe about being able to keep the engine running is something I've seen quite a few times with burnt-out/corroded plugs.
captain america is offline   Reply With Quote
Old 05-16-2010, 05:45 PM   #5
Default re
how about starting with what engine it is what fuel and glow plugs are you using and how much runtime on the motor?but it does sound like the rod bushing or main bearing going bad
toofless is offline   Reply With Quote
Old 05-16-2010, 05:50 PM   #6
Trader Rating: 24 (100%+)
If the element is being pushed into the plug, it is usually a worn rod or crank pin. A head not shimmed enough/correctly can burn plugs out also.
Jeff Ford is offline   Reply With Quote
Old 05-17-2010, 08:09 AM   #7
rc skyline's Avatar
Another thing to remember is after run oils... If you fire your engine up full of after run it usualy leads to premature glow plug failure
Did you happen to do that at all?
Dave
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Old 05-17-2010, 08:22 AM   #8
Madbrad's Avatar
Trader Rating: 29 (100%+)
I would go back to factory settings on the needles and start from there.
How does it run for the time that it does run ?
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
RB Concept Engine Thread.. r1harper Offroad Nitro Engine Forum 3632 06-14-2017 12:29 AM
Engine eating glow plugs Bengsch85 Nitro Off-Road 24 05-17-2010 07:55 PM
Could a worn clutch cause blown glow plugs? aradaiel Nitro Off-Road 13 06-28-2009 11:06 AM
Killing glow plugs somehow pracy Nitro Off-Road 11 07-02-2008 05:41 PM
