Old 05-14-2010, 08:55 PM   #1
jeff_ellis_9's Avatar
Default Losi 8, steering ackerman and bump steer questions
What are the advantages and disadvantages of using UP or DOWN bump steer and using the SHORT and LONG steering ackerman? What gives you what?
Thanks in adv.
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 05-15-2010, 05:04 AM   #2
cdbias's Avatar
Bump steer up gives you a little more steering in the center of the turn. Bump steer down is just a smoother, more constant "arc" in the curve.
Ackerman:
Long is what most people run. It's much smoother and doesn't make the car as twitch.
Short ackerman makes the front end very sensitive to wheel input but will also give you quicker initial turn in.
Personally, I like the long ack on buggy and the short ack on truck.
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 05-15-2010, 05:09 AM   #3
Slider30250's Avatar
Running the bump steer ball down will give you smoother steering mid corner (less bump-steer), running the ball up will give you more bump-steer mid corner (steering will seem more twitchy). The short ackerman plate will increase steering response right off center (more sensitive) and has more steering mid turn. The long ackerman plate is less sensitive off center and is more forgiving, you are less likely to get too "happy" with you're steering.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
losi 8ight setup basic questions teeforb Nitro Off-Road 17 08-15-2012 05:12 PM
