Old 05-14-2010, 12:51 PM   #1
Default cant get losi 8 started
I just bought a Losi 8 rtr and cant get it started. Its a 350 that came with it. I used the box it came with and striped the wheel belt. Called losi they sent me better two motor box. Got it started didnt last long. Getting stuck at top dead center. Release it with screwdriver, heat engine up etc. My new box is gettin ruuber wear from the tight flywheel. Called local hobby. They said called losi. Losi said send it in. Is it possible it is to tight, bad engine, user error. Help.. Frustrated
surg is offline   Reply With Quote
Old 05-14-2010, 12:55 PM   #2
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
Most new motors are a pain to start because there is so much pinch. I recommend heating it up to around 200 degrees and then putting some aluminum foil around the head to keep the heat in the motor. It should be easier to start the motor, but all new motors are like that for the first few tanks.
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
CJ Weaver is offline   Reply With Quote
Old 05-14-2010, 12:57 PM   #3
markr04's Avatar
New engines are tight, and it seems that the latest generation of engines are even tighter when new. Just keep heating it up before starting.
I really recommend going to your local track and getting help from someone with experience. There's only so much that can be done via text in a forum. I'm always helping n00bs at my track because people helped me when I was a n00b.
But... you may need to lean the engine some just to get it started, then richen it again after it's started for break-in.
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Having problems starting my O.S Vpec in my Losi 8ight Please help NJA82 Nitro Off-Road 12 09-20-2007 04:18 AM
