Old 05-14-2010, 01:07 AM   #1
Greenlee37's Avatar
Trader Rating: 32 (100%+)
Default EB Mods pipe
Question #1 - I picked up one of these a few years ago when they came out. I really like this pipe. Does anyone have one they might want to get rid of? I cant seem to find one anywhere
Question #2 - I have a leak between the exhaust port of the motor and the pipe. Before you even advise, I have installed 2 different brand new OS exhaust gaskets.. still leaks.. I assume that the header flange has worn becasue the roundness still looks true.. Anyone have any tips or advice on how to remedy this? I thought about spreading some black non-hardening silicone(like I use to seal backplates and carbs) around on the inside of the header pipe flange and letting it dry, then mounting back on the motor. I am thinking this would be better than installing the header when the silicone is wet so then I might be able to remove and re0install the pipe without the silicone "sticking" the two together... Any comments? Thanks in advance
Greenlee37 is offline   Reply With Quote
Old 05-14-2010, 05:26 AM   #2
tracyabshire's Avatar
What header gasket are you using.I use the hpi header gaskest on my 2041,it is thicker than all the other ones.It is a purple color one.
tracyabshire is offline   Reply With Quote
Old 05-14-2010, 08:08 AM   #3
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Default 2041 gaskets
You need a beefy gasket on the 2041 cause the opening in the header is slightly larger then average. I like the onfa ones
http://www.amainhobbies.com/product_...xhaust-Seals-2
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 05-14-2010, 09:43 PM   #4
Greenlee37's Avatar
I will try some thicker header gaskets.. just didnt think about that becasue when this pipe was new, 2 years ago or so, it fit and worked just fine on a speed motor... not the same motor now, but still a speed, and just cant get it to seal... will try the thicker gaskets you said.... if still doesnt fit, will just find a new header that fits... thanks for your replies and thanks for the PM replies also..
Old 05-15-2010, 08:57 AM   #5
scoobie1's Avatar
Its not black coated like the EB pipe, but Reckward Tuning has a chrome 2041 pipe....Both the EB and the Reckward are re-badged Meikle 2041 pipes.
http://www.amainhobbies.com/product_...ine-Tuned-Pipe
I live with fear every day...sometimes she lets me race!!!
scoobie1 is offline   Reply With Quote
Old 05-15-2010, 02:09 PM   #6
Greenlee37's Avatar
thanks for this info... I will look into it...
Old 05-17-2010, 05:26 PM   #7
Greenlee37's Avatar
which manifold do you prefer on this pipe? short angled or long curved? Current EB version has the long curved header, but running the short angled one will give more bottom end and the epxense of losing a little top end.... Any of you have a preference on the 2041??????
Old 05-19-2010, 12:30 AM   #8
Greenlee37's Avatar
any comments?
Old 05-19-2010, 04:54 AM   #9
JUD
JUD's Avatar
any comments?
I would go with the one that gives you more bottom end. Considering your only on the straight on an average of 3 to 4 seconds. The rest of the track is mostly low to midrange.
JUD
Mugen Seiki - AB Mods - AIRTRONICS - Ninja - CR Graphics - Spektrum
JUD is offline   Reply With Quote
Old 05-19-2010, 07:32 AM   #10
jpalessi's Avatar
i run the tight mbx 80 header cause it fits in the car the best.. lost a lil bit of bottom but gained some top.
Joe Alessi
www.Lucky7RC.com
Old 05-19-2010, 07:35 AM   #11
hambone's Avatar
The shorter the manifold the more topend/less bottom you will have. Longer gives more bottom, shorter has more top.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 05-19-2010, 10:43 AM   #12
Greenlee37's Avatar
A Main must have a typo then, cuz when I look at both of the Nova manifolds, it is explained the opposite...
Old 05-19-2010, 10:52 AM   #13
hambone's Avatar
Then A Main has a typo.
Rob Hamm
The Nitro Shop
Bones Motorsports
Snow Monkey Racing
Old 05-19-2010, 01:43 PM   #14
n.e.r.d's Avatar
EB had the manifold's length custom made for the v-spec, works best for the 2041 apparently..
In your opinion, how will the EB pipeset be better than the OS 2060?
runtime? power?
Back to your qn 1, I have the EB pipeset and am willing to sell it to you but shipping won't be cheap cos I'm on the other side of the world..
n.e.r.d is offline   Reply With Quote
Old 05-19-2010, 01:50 PM   #15
scoobie1's Avatar
All the Nova manifolds appear correct to me...which manifold/manifolds are wrong?
