Old 05-13-2010, 05:49 PM   #1
jeff_ellis_9's Avatar
Default Losi Mach 427 pictures and HELP please!
Can somebody please post close up pictures of their Losi Mach 427 engine on a 8ight of each side view?? I need to see two things, which way the carb ret. post goes and if you have a spring set up on your carb to assist on the return of the throttle (NOT the spring on the throttle linkages). I have seen a picture before where somebody had a spring that looks similar to the header spring wrapped around the carb to help return the throttle piston thing.
Reason I post all this is, one day I was out driving and lost my carb. ret post and I bought another one and I am not quite sure which way it goes. As of now I have the threaded end toward the exhaust pipe. And every time I drive, the vibration knocks it loos causing my whole carb to be loose. And YES I have tried loc-tite, let it sit over night, and still comes loose. Now I will note that I am in need for some O rings that go on the carb end that goes into the engine. Would that make this happen? Or am I doing something wrong?? Have it inserted the wrong way?? Or did I order the wrong carb ret. post all together?? Also, im not sure if the loose carb is causing this, but I can't seem to get my idle down, I turn the screw counter clock wise but nothing. But when I push in on the throttle linkage side it idles down (reason I may need the spring there)
jeff_ellis_9 is offline   Reply With Quote
Old 05-13-2010, 06:32 PM   #2
bump. anything?
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
Old 05-13-2010, 06:43 PM   #3
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
i dont have it in a buggy but here is a old pic i dnt have the motor anymore so couldnt post new pics hope this helps
there not very good but hope it helps
and for ur carb pushing it closed if ur linkadge is right the carb should closeto ur idle position without it closing anymore when u apply break
Losi Mach 427 pictures and HELP please!-motors-001.jpg   Losi Mach 427 pictures and HELP please!-motors-002.jpg   Losi Mach 427 pictures and HELP please!-motors-003.jpg
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 05-13-2010, 06:46 PM   #4
any ideas on my carb ret. post not staying tight?
and its hard to tell by your pictures. I need to see the ret. post up close. As to which way it goes
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-13-2010, 06:49 PM   #5
no mine stayed tight someone will know give it time
Old 05-13-2010, 07:00 PM   #6
mudboger07's Avatar
Are you talking about the pinch bolt? If it's not staying tight, You may have bought the wrong one? See if you can order another one, they should go in either way left or right side, I'll look on my 350 the should be the same.
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 05-13-2010, 07:27 PM   #7
if ur palking about pinch bolt mine went in from the side ur pipe would be on left from looking at the back of the motor
Old 05-13-2010, 07:27 PM   #8
YES!! pinch bolt, thats it. But im searching for it and im only finding one for a Losi Nitrotech R21 and Losi 350 and 454. Will either of those fit my 427 .21 engine? And by looking at the pictures, it looks much different than the one i ordered
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-13-2010, 07:49 PM   #9
pyromania's Avatar
Trader Rating: 18 (100%+)
http://www.horizonhobby.com/Products...ProdID=DYN0911
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 05-13-2010, 08:46 PM   #10
i think the mach is a .28 motor not a 21 not shure
Old 05-14-2010, 12:31 AM   #11
hookem34's Avatar
Trader Rating: 17 (100%+)
Hey Jeff just curious. Are you out of Houston, TX? Reason I ask is I had a buddy with that name that I have not seen in a while since I moved away from Houston.
hookem34 is offline   Reply With Quote
Old 05-14-2010, 05:08 AM   #12
pyro, thats the one I already have and is not working. by the looks of some pictures I have found of the motor it has one like that but the center of it looks kinda separated with threads, maybe to kinda "squeeze" in on the carb, holding it tight.
I cant post a link yet for some reason, but go to
ampdraw.com and beside part number type LOSR2228.
Would that one work for the Losi 427 engine??
.28?? Its not a .28 but I was wrong, it IS a .27 engine. I looked it up on losi web site
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-14-2010, 11:38 AM   #13
bump. sorry I keep bumping this. My buggy is down until I get the right pinch bolt ordered. Thanks for all the help so far
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-14-2010, 11:49 AM   #14
Madbrad's Avatar
Trader Rating: 29 (100%+)
Im pretty sure the mach .28 will fit. I used the Mach .28 back plate on my 427 to covnert it to a bump start.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
