Need Help about OS Pro Mod Motor
Guest
How can I tell if it is a Pro mod motor or just a reg vspec? Besides the drilled head. Please help. Mike
Easiest way to tell without pulling it apart is the crankshaft. The Pro Mod has the black DLC coated crankshaft. Normal v-spec is just raw steel. The Pro Mod crankshaft is also silicone filled and has 2 tungsten slugs in the counterweight. You'd have to have the backplate off to see that though.
you don't have to take the engine apart to tell if the crank is coated
bout to fire up my own version of a modded vspec. Say a prayer
Then I said "The Pro Mod crankshaft is also silicone filled and has 2 tungsten slugs in the counterweight. You'd have to have the backplate off to see that though."
Get it now dreaux???
I know. I said "Easiest way to tell without pulling it apart is the crankshaft. The Pro Mod has the black DLC coated crankshaft. Normal v-spec is just raw steel."
i ran my dremmeled crank and my super lightened rod and ported sleeve a little while ago.
FAAAASSSSSTTTTTTTT!
But it wont's idle think i took to much off the crank face. Nevermind that the p/s set i used i could push the piston all the way out
Man you want to see a real KNIFE edged rod? you could cut with the one i grinded
but let me tell you, i am going in the right direction. A sleeve that was not so worn out it would have ran alot better. But man it was flat out flying!!!
FAAAASSSSSTTTTTTTT!
FAAAASSSSSTTTTTTTT!
i live far from the nearest track and work alot. I might be able to go to the track maybe twice a month. So i have to entertain myself any way i can. I am working on a custom break in bench too. Thinking about drilling out the next crank i do. Fill it with puddy but don't know which kind to use. after studying engine mods for a while now and i can closely look at the vspec and ninja crank and see big differences. The ninja crank is not only lightened, filled and coated, the face of the crank has far more aggresive machineing on it. The intake port has sharper degrees on the side of the throat and it has 2 turbo cuts on the crank as opposed to 1 on the vspec. But the vspec has a smoother transition out the throat of the crank. All in all the ninja crank looks superior in dynamics and timing. In reality the cranks on the ninja and speed are optomized. there is litterally nothing else you can get out of it. But i am sure a modder would tell me otherwise.
It really is an excellent upgrade for 100$
