Old 05-13-2010, 11:21 AM   #1
Trader Rating: 39 (98%+)
Default RB S3 question
Can someone tell me what the older S3 run at for temps? Mine likes to run pretty hot and I know to tune by performance and smoke but I just want to hear from others who ran this motor before and see what temps the were running at. Thanks.
dayglo33 is offline   Reply With Quote
Old 05-13-2010, 01:27 PM   #2
8&stuff's Avatar
Trader Rating: 55 (100%+)
right around 240 should be good. up to and around 260 is normal with almost empty tank. as you said... look for good smoke&perfomance out of it more so than temps. also cheaper temp guns run 20degrees and more higher than high end(such as exergen). doesnt matter as long as you are aware of the possible inconsistancies of the particular gun you are using and adjust accordingly
8&stuff is offline   Reply With Quote
Old 05-13-2010, 10:51 PM   #3
merdith6's Avatar
Default Yes
130-150 F. It's a great engine, just likes to be a bit lean on the bottom, make sure it has plenty on top though.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Engine Mod Question mdbrowdy1 Nitro Off-Road 15 08-20-2009 09:09 PM
rb s3 turned into a 5 port losiracer22 Nitro Off-Road 12 11-06-2008 05:06 PM
inside pic's of 3port rb i modded mfroot Nitro Off-Road 33 07-09-2008 06:57 PM
