Old 05-11-2010, 09:43 PM   #1
Default small oil ring on the front bearing?
when i take my flywheel off, there is a small oil ring around the inner seal on the front bearing. I have seen this many times when i take the flywheel off, and maybe i am being paranoid. But is this normal? Bearings are not gritty and relatively new.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-11-2010, 09:46 PM   #2
tc5 man's Avatar
if it isnt a lot i wouldnt worry about it is it running good ? sometimes if the engine is really rich than can happen, too but if its a lot i would change it.
Old 05-11-2010, 09:46 PM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Perfectly normal! No bearing is completely leak free. They will all leak a little bit of oil out. When it gets to be a problem is when it is leaking a lot of oil out. That's when you know there is a larger than normal leak and the possibility of an air leak. At that point the bearing should be changed, but you know that.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-11-2010, 09:51 PM   #4
Yeah. Just checkin. I knew you guys would think i was trippin
now i can sleep
HOW SAD IS THAT!
Mugen
Old 05-11-2010, 09:54 PM   #5
now i can sleep
HOW SAD IS THAT!
Another great dreaux moment.
-Koby Kubrin-
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
EP 1/10 Touring zafira2310 Indonesia Racing 10142 06-18-2010 11:09 PM
V-Spec front bearing issues Jonro Nitro Off-Road 35 09-06-2008 10:04 PM
