Old 05-11-2010, 07:38 PM   #1
Default help plz
i have a modded picco p3 .28 and at high rpm it seems to load with fuel and die but if u just keep bumping the throttle it will go i have tried 3 different carbs on it and they all do the same anyone got any ideas
sidekick91 is offline   Reply With Quote
Old 05-11-2010, 07:41 PM   #2
Shoaf85's Avatar
Trader Rating: 19 (100%+)
Have you tried a new glow plug?
Team AE all the way...
FASTLANE GRAPHIX !!!!!!!!
Shoaf85 is offline   Reply With Quote
Old 05-11-2010, 08:03 PM   #3
yes i have im using os p3 (turbo) and 20% sidewinder nitro fuel
Old 05-11-2010, 08:23 PM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
Lean out the hsn and see what happens. If it gets worse then richen it. If you are lost go back to factory settigs and try again.
Old 05-11-2010, 08:30 PM   #5
ive tried both ways if i lean the high speed it just gets worse and if i richen it then it runs really bogish and does the same thing , i just ran it out side had to start it twice then i leaned the low speed a hair and it ran great for half a tank no problems then it died so i started it again and same problem again with dying at mid to high rpm
Old 05-11-2010, 08:31 PM   #6
trevor15308's Avatar
Send a message via Yahoo to trevor15308
how many gallons are on ur motor
AGAMA RACING-TKO BEARINGS-AIRTRONICS-SIDEWINDER-WERKS-PROLINE-VP PRO USA-RCrenew.com
trevor15308 is offline   Reply With Quote
Old 05-11-2010, 08:39 PM   #7
um not sure i bought it used i think the guy that i got if from said about 2 gallons on it then repinched and modded and then i but 2 tanks throw it sitting at 220f and then boged it around the yard at 1/4 throttle or so keeping the 220 temp then started or attempted to start to tune it but it dont matter if its to rich on the high speed or to lean it dies at mid to full throttle so i have not got very far with it
ninja jx .21 help plz downunder23 Nitro Off-Road 20 02-19-2009 01:00 AM
Jatto 3.3 (help plz) IluvRC Nitro On-Road 10 11-02-2008 06:43 PM
servo help... plz..... help...... plzzzzzz hobbs Malaysian R/C Racers 13 08-02-2007 07:17 PM
HOW DO I REMOVE A FLYWHEEL??? HELP PLZ paul73rc Nitro On-Road 15 06-23-2007 07:33 AM
Melbourne RC-er's help plz! BrainTeased Australian Racing 31 02-06-2004 06:55 PM
