Old 05-11-2010, 07:08 PM   #1
Trader Rating: 48 (100%+)
Default engine?
Hi I have a novarossi p5xl I changed the crankshaft to a putty filled one, new ceramic bearings front and rear no slop in rod I s it normal to take like 25 to 30 seconds to idle down from a high or low speed run It then idles fine It also has good smoke coming out could it be a air leek?thanks.Tim
Tim G is offline   Reply With Quote
Old 05-11-2010, 07:18 PM   #2
ScottyM's Avatar
Trader Rating: 27 (100%+)
I had this problem over the weekend and it turned out to be a dirty air filter cause the LSN to be rich.. If your air filter is realtively clean, mine was NASTY NASTY, thne your bottom end is a touch rich.. Lean it out an hour at a time, until it drops right to idle with out any further dropping, after being hard on the throttle.. Make sure to keep adjusting the idle speed down too..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 05-11-2010, 07:20 PM   #3
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
Trying richening the bottom a little bit as a lean bottom causes that problem. By the sounds of things it is an air leak. If it is still doing it after richening the bottom, replace the fuel line and fuel tank. If it is STILL going it, take the backplate and carb off and seal them. Then make sure the rear engine gasket and pipe gasket isn't damaged.
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
CJ Weaver is offline   Reply With Quote
Old 05-11-2010, 07:20 PM   #4
JarheadRCGuy's Avatar
Send a message via AIM to JarheadRCGuy Send a message via Yahoo to JarheadRCGuy
sounds like your low speed could be a little on the lean side. i would also double check your idle speed screw setting. that would be my first course of action.
Tango Down Grafix | Tweeked Monkey Racing | Team Terribles
What? You're upset that the track is blown out? Guess what? It's called OFFROAD FOR A REASON!
JarheadRCGuy is offline   Reply With Quote
Old 05-11-2010, 07:28 PM   #5
tc5 man's Avatar
whould a to small of a gap on the idle, cause it to drop like that yea it could be a leak but i also think a rich top, end and a leaner lsn whould do that also.
Old 05-11-2010, 07:30 PM   #6
CJ Weaver's Avatar
If you can pinch the fuel like and it doesn't shut off after 6-7 seconds, your bottom end is too lean. That is what causes it to "run-on" after giving it throttle.
Old 05-11-2010, 07:33 PM   #7
tc5 man's Avatar
really i though if you pinch the fuel line, and it shuts off right away than its too lean but everyone has a diffrent method. and also no smoke coming out of the pipe .
Old 05-11-2010, 07:35 PM   #8
CJ Weaver's Avatar
Personally, I just close my eyes and turn needles into I get it right
Old 05-11-2010, 07:39 PM   #9
tc5 man's Avatar
lol im not the best tuner but i know, when the lsn is a bit rich and theres no punch.
Old 05-11-2010, 07:42 PM   #10
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Agreed, a run-on is caused by a lean bottom end. If it is running on after a high speed runs, the bottom end is most likely too lean. Richening the bottom end will fix this issue.
If it is just giving you a "two stage idle" it is possible that the bottom end is in fact too rich and the idle gap too large causing a false idle. In this situation the engine will come down to one idle and after the case loads up from the rich bottom end it will come down to a second idle. Leaning the bottom out and lowering the idle will fix this problem.
My suggestion if you are new to tuning is to go back to factory settings and re-tune from there. It can get a bit confusing to work through the odd issues like this one if you don't have a good set of base line settings.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-11-2010, 07:43 PM   #11
houston's Avatar
Trader Rating: 91 (100%+)
Make sure you didn't rip the oring in the block where the carb seals on the bottom , trust me , it will play havoc with your tuning . If the idle is a tingy idle it is too lean , if it is a consistant idle then it is a bit rich .
The pinch test should yield an idle up in 2-3 seconds and die out in 5-8 seconds
Tuning the low end on an engine is the real art of carburetor tuning
And another thing , it is sooooo hard to tune an engine third hand over the pc
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-11-2010, 07:45 PM   #12
CJ Weaver's Avatar
Why don't you tune my motors then?!
Old 05-11-2010, 07:46 PM   #13
tc5 man's Avatar
you have learn your self man thats what im trying to do.
Old 05-11-2010, 07:46 PM   #14
Hahaha.
-Koby Kubrin-
Old 05-11-2010, 07:48 PM   #15
CJ knows more about tuning engines than he is letting on.
-Koby Kubrin-
Houstons Engine Service H.E.S. houston Offroad Nitro Engine Forum 8821 06-17-2017 12:29 PM
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
Ninja Engine by GRP ogreasurada Offroad Nitro Engine Forum 1526 09-16-2013 07:13 PM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 10:48 AM
