Old 05-11-2010, 08:00 PM   #16
tc5 man's Avatar
Originally Posted by JAMMINKRAZY View Post
CJ knows more about tuning engines than he is letting on.
oh i see, i dont know if you guys seen, this but there is a website that sells these things that tell you, where you tune your high end at. and how many turns you turned the needle, im serouisly thinking about getting one too.
Old 05-11-2010, 08:02 PM   #17
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
Link?
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
CJ Weaver is offline   Reply With Quote
Old 05-11-2010, 08:04 PM   #18
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I don't buy it. No device can race tune an engine for you. That is an art you have to master. It will take time, but once you get enough experience with it, it is pretty simple(for the most part. There are the occasional WTF moments.).
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-11-2010, 08:06 PM   #19
tc5 man's Avatar
Originally Posted by CJ Weaver View Post
Link?
www.R/C Hardware.com
its on beatyourtruck.com its on the reviews on their site.
sorry its www.rchardware.com
Old 05-11-2010, 08:08 PM   #20
Audiobahnaholic's Avatar
Trader Rating: 42 (96%+)
There are many ways to tune a nitro engine but I figure this is the most simple way to do it. This technique is for a fully broken in engine that is ready for a full performance tune. This tuning procedure will set your needles to where they need to be for optimum performance, the engine will tell you all you need to know.
For this method to work the engine has to be at running temperature (or as close to it as possible) as well as having the standard 1mm gap for the carburetor opening.
High Speed Needle
Pull a full throttle pass a couple of times and listen to what the engine does when you let off the throttle. If the it drops right to idle, the HSN is either good or on the rich side. At this point you can lean the HSN in 1/12 turn increments until the idle seems to hang a little after a full throttle pass. If it starts to idle high after a pass it is just on the lean side of a perfect tune. Back the HSN out 1/12 turn at a time after a wot pass until the engine drops right to idle after a pass. Now your HSN is set.
An explanation to what is happening is simple - if your HSN is too lean, after a full throttle pass when you let off the throttle the engine is still lean causing the idle to hang and idle high until the LSN has a chance to take over and meter the right amount of fuel to bring the idle down to normal running speed (given the LSN is set correctly).
If the opposite happens, after a full throttle pass when you let off the throttle it drops to a good idle right away and then starts to idle back up too high, this is a sign that the LSN is too lean. If it comes off full throttle with a good tune and will drop RPM nicely then the HSN is metering the fuel properly but once it hits idle the LSN being too lean will quickly take over causing the RPM to go back up.
Low Speed Needle
Most of this setting was explained above but there are a few little tricks you can use to make sure the LSN is adjusted perfectly. We all know that you don't tune for temperatures, but a temperature gun is very handy for this part. After some full throttle passes with the engine good and warm, bring it in and let it sit for about 10 seconds. At this point take your temperature gauge and hold it as steady as possible on the head, what you want to see is the temp dropping a degree every 4-5 seconds. You want the temp to drop very slightly at idle because when your off throttle the engine should be cooling, if not, the temps will keep pushing higher during on and off throttle running and will cause temperature issues.
This is how I do it and I have tuned a lot of engines for people, whether bashing or racing. I have seen across the board from beginners to veterans that when they hear the high idle after a pull, the first thing they go for is the LSN when in fact it is the HSN causing the issue.
I use this method for all my engines and it works. I am pulling OS Speed's everywhere on the track with my $225 Jammin 21.
Audiobahnaholic is offline   Reply With Quote
Old 05-11-2010, 08:09 PM   #21
tc5 man's Avatar
i get what your saying but this thing, reminds you where you have your high end tuned at its good for, guys learning like me still. but i do tune for performance and smoke not temp. usally if theres smoke coming out of pipe than you should be ok.
Old 05-11-2010, 08:21 PM   #22
Frank L's Avatar
Trader Rating: 148 (100%+)
I am just waiting for the little ecu and fuel injection kit to bolt on and solve all my tuning problems forever.
Old 05-11-2010, 08:24 PM   #23
I wouldn't hold your breath on that one.
-Koby Kubrin-
Old 05-11-2010, 08:31 PM   #24
tc5 man's Avatar
be carefull what you wish for on that , more cost $$$ and i think it would be more of a pain cause theres more things to go wrong.
Old 05-11-2010, 08:51 PM   #25
Frank L's Avatar
Starting to turn blue here. Is it here yet???
Old 05-11-2010, 09:01 PM   #26
-Koby Kubrin-
Old 05-11-2010, 09:04 PM   #27
houston's Avatar
Trader Rating: 91 (100%+)
a 2,000$ unit for your 300$ engine classic
sooner or later though , i am sure it will happen
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-11-2010, 09:09 PM   #28
Frank L's Avatar
Ahhhhhhh I can breathe again. Whewwww I aS turning purple. Thanks Monty. So where do I get one or better yet two?? Jk
Old 05-11-2010, 09:11 PM   #29
Trader Rating: 520 (100%+)
I would bet for $2000 Monty will come and tune your engine for you..?
flame56mx is offline   Reply With Quote
Old 05-11-2010, 09:11 PM   #30
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Rc DFI would be dialed.......
Ill hold my breath tooo
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Houstons Engine Service H.E.S. houston Offroad Nitro Engine Forum 8821 06-17-2017 12:29 PM
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
Ninja Engine by GRP ogreasurada Offroad Nitro Engine Forum 1526 09-16-2013 07:13 PM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 10:48 AM
