Old 05-11-2010, 08:25 AM   #1
chewie219's Avatar
Default Screws to tight
What do you do when you can't get screws loosened up? I have some screws that hold the engine mount to the chassis that I can not get unloosened. Please help.
Chewie219 - OFNA 9.5 Buggy, RC10Gt w/OS .15
chewie219 is offline   Reply With Quote
Old 05-11-2010, 08:30 AM   #2
1fastdude's Avatar
Trader Rating: 15 (100%+)
Try using a heat gun, usually that helps even if its loctited.
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 05-11-2010, 08:34 AM   #3
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
heat gun works great
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 05-11-2010, 08:40 AM   #4
merdith6's Avatar
Default L wrench
I keep one of the 2.5mm L shaped wrenches that come with the kits and put fuel tubing on them. It will break them loose......
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 05-11-2010, 08:42 AM   #5
trevor15308's Avatar
Send a message via Yahoo to trevor15308
i use a heat gun or a soldering iron and put the tip on the screw or i tapp it with a hammer a lit bit
AGAMA RACING-TKO BEARINGS-AIRTRONICS-SIDEWINDER-WERKS-PROLINE-VP PRO USA-RCrenew.com
trevor15308 is offline   Reply With Quote
Old 05-11-2010, 08:44 AM   #6
JarheadRCGuy's Avatar
Send a message via AIM to JarheadRCGuy Send a message via Yahoo to JarheadRCGuy
Here's the best steps to follow, and make sure you do them in order:
1. Go to local auto parts store
2. Buy one (1) 16 oz "Can O Man"
3. Go home and grab appropriate tool
4. Proceed to loosen stuck screws!
Just kidding! All the above tips should help you out just fine!
Tango Down Grafix | Tweeked Monkey Racing | Team Terribles
What? You're upset that the track is blown out? Guess what? It's called OFFROAD FOR A REASON!
JarheadRCGuy is offline   Reply With Quote
Old 05-11-2010, 08:45 AM   #7
Frank L's Avatar
Trader Rating: 148 (100%+)
If all else fails use a dremel and slot it and use a big blade screwdriver. But definatly try the heat gun 1st
Old 05-11-2010, 08:56 AM   #8
jamiekerr14's Avatar
Yea heat gun-Then make sure the screw head is clean-No mud drime in there-New Hex tip, Or a good condition one.. and then try.. last resort as mentioned above dremel small slot then use a flathead to take it out. I try to replace my engine screws on a frequent basis. As there are prone to getting stuck, and the hex getting chewed up on rocks ect..
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 05-11-2010, 08:58 AM   #9
losi_racer's Avatar
Trader Rating: 25 (100%+)
I've heard heat gun a lot, that's never wokred for me unless its loc tite holding it in. I usually go with the L shape wrench but I've had some screws so tight it just twist the wrench lol. If that don't work I spray wd40 on the screw and wait couple min, this usually does the trick, if not its dremel time
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-11-2010, 11:19 AM   #10
jbright33's Avatar
i think thats what he was asking for was motor screws asumming theres loctite on them
JESSE BRIGHT
Old 05-11-2010, 11:24 AM   #11
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
I had one the other day that just wouldn't break loose, but I pulled all the other screws out, held the screw with a hex driver and rotated the engine mount in the chassis to get it free. I've had way better luck doing that than the heat gun. Like losi racer said, that only seems to work if you've used loctite.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 05-11-2010, 11:29 AM   #12
chewie219's Avatar
Freaking hilarious. I should have figured I would get a response like that. I will try the heat gun method first. If all else fails maybe my wife can do it.
Old 05-11-2010, 11:48 AM   #13
If it's on a sturdy enough part, or if you can put that part on something solid, then an impact driver works spectacular. The kind you put on the screw, turn slightly then hit with a hammer. The hammer impact both presses the bit into the screw (no slipping) and turns the bit. Probably less than $20 at Sears.
MattFL is offline   Reply With Quote
Old 05-11-2010, 11:54 AM   #14
I couldn't resist!
Old 05-11-2010, 11:55 AM   #15
Another option is to use a screw extractor....just drill a small hole down the centre and use the screw extractor...
If you have hardened screws this won't work. It may do if you have a drill bit that will drill them (carbide?)
Jaf1977 is offline   Reply With Quote
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1144 01-04-2010 03:49 AM
I've just read on LosiBk2.com that Team Losi are not sending a team to the worlds. Mabuchi540 Electric Off-Road 170 09-18-2007 04:32 AM
Engines leans down a lot once tank gets to 1/4 full WeatherB Onroad Nitro Engine Zone 25 03-09-2006 04:56 PM
I Messed Up My Engine Bolt Screws! Plz Help! QuickSilver1024 Nitro On-Road 19 03-31-2004 05:23 AM
