Old 05-11-2010, 12:04 PM   #16
Heat Gun has always worked for me. just got to get it hot enough...
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-11-2010, 12:07 PM   #17
Trader Rating: 74 (100%+)
You shouldn't need lock-tite on the chassis screws that are counter-sunk. Those suckers are hard enough to remove without lock-tite. I just went through this very routine last week. Typically by the time you figure out the screw won't budge, you've already stripped the SOB.
Heat guns don't typically work because the screw and chassis are flush and you just end up heating both the screw and the chassis at the same time. The heat gun may work if lock-tite is the only thing holding the screw in place, but that is unlikely.
I don't advocate the use of a dremel to cut a slot in the screw head. Since those screws are already flush with the chassis, that means you're probably going to cut a slot in the chassis too. Cutting a slot in a screw head with a dremel works great when the head of the screw is exposed, because then you're only destroying the screw.
You've probably gone past this step, but like the others have said make sure there is no dirt in the screw head so that you're wrench fits all the way down in the hex. If the wrench doesn't fit all the way in the screw head, you're going to strip the screw head. Make sure you're using a good hex head wrench too. If your hex wrench is already rounded just a bit or isn't the correct size, you're going to strip the screw head. Go slow and put pressure on the outermost part of the hex wrench to get the most leverage.
If you end up stripping the screw head (which happens 75% of the time), use a drill to drill out the screw. Find a drill bit with the same diameter as the screw threads, and make sure you have some hard ass drill bits. Start drilling into the hex portion of the screw head and make sure you're going in straight. By the time the drill reaches the point where the head of the screw meets the threads, the drill should have separated the head from the screw threads. If it hasn't, get the next size bigger drill bit and repeat. This pops the head of the screw off without doing any damage to the chassis.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 05-11-2010, 12:16 PM   #18
ALWAYS worked for me. Metal gets softer with heat...... But you have to get it hot enough.
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1144 01-04-2010 03:49 AM
I've just read on LosiBk2.com that Team Losi are not sending a team to the worlds. Mabuchi540 Electric Off-Road 170 09-18-2007 04:32 AM
Engines leans down a lot once tank gets to 1/4 full WeatherB Onroad Nitro Engine Zone 25 03-09-2006 04:56 PM
I Messed Up My Engine Bolt Screws! Plz Help! QuickSilver1024 Nitro On-Road 19 03-31-2004 05:23 AM
