Old 05-10-2010, 08:24 PM   #1
Default please explain
me and my friend were at a race and his truggy was lean boging, we brought it into the pit area and it wasn't that hot but i noticed it wouldn't idle, so i raised the idle screw a couple hours at a time until it would hold a idle(i think about 4 hours total) and then after the engine reached alittle over 200 i checked the low speed on the box and it checked out fine, we put it out on the track for the 20min main and the engine ran great the whole time with no lean bog at all. did by raising the idle richen the low speed? any help would be great if u have experienced this or understand
speedzone99 is offline   Reply With Quote
Old 05-10-2010, 08:30 PM   #2
Cory Kerber's Avatar
Sounds like you had an overlean lsn to compensate for the low idle.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 05-11-2010, 07:38 AM   #3
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Doesn't sound like you had a lean bog, sounds like the bottom end was too rich. By opening up the throttle gap you made the mixture leaner by adding more air thus it would idle and run ok.
You should revisit the tune and lean the bottom out and then reset the idle.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 05-11-2010, 08:08 AM   #4
thanks man i think u r right, i normally tune my engines with the idle higher than it should be and then work it down, the motor ran great the rest of the day, its a axe rossi X2 cobra, literally all i did was up the idle where it would idle and rechecked the lowend by counting 10 seconds and then wide open on the starter box and it slightly loaded up and then cleared out like it should and problem was gone.
Can somebody please explain this to me? sho .21 R/C Racers 4 Christ 222 11-18-2011 02:06 PM
I dont get "shimming" please explain... assivaen Nitro Off-Road 29 01-21-2009 09:45 PM
Can an electric moderator please explain... squarehead R/C Tech Site Forum 14 03-06-2008 01:21 PM
Unespected handling due to shock oil change - please explain Cole Trickle Electric On-Road 59 01-11-2004 12:00 PM
