Old 05-10-2010, 05:42 PM   #1
Troy_Konitzer's Avatar
Location: Abrams, WI (Yes the same town as CJ & John Greaves)
Default Holes in Tires
I mounted a set of AKA City Blocks with the AKA foams on AKA rims and CA glued them without adding the holes in the tires. What's the best solution for adding the holes now? How big should they be? I've used holes in the rims in the past and the foams get ruined too fast. Thanks for any advice.
Just remember...........it's only a part number! They'll make MORE.
All the RC websites called me today ...... they recommend promoting your local hobby shops!
Troy_Konitzer is offline   Reply With Quote
Old 05-10-2010, 06:14 PM   #2
jammin32j's Avatar
I have used lexan scissors and cut a little v shape in the tire before when I forgot to punch holes in them before I mounted them. I have also used a dermal with a 1/8 inch round metal cutting bit and pulled the tire up from the foam and ground through the rubber. Just make sure you dont get into the foam.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 05-10-2010, 06:58 PM   #3
tennvol11's Avatar
Trader Rating: 8 (90%+)
Whats the benefit of doing this?
tennvol11 is offline   Reply With Quote
Old 05-10-2010, 07:00 PM   #4
losi_racer's Avatar
Trader Rating: 25 (100%+)
it will sling water and dirt of of the tire instead of just sitting there,
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-10-2010, 07:04 PM   #5
When the holes are in the tires mud and water have a way to escape. If the holes are in the rims the dirt will stay in unbalancing the tires and ruining the foams.
I used the dremel tool with a 1/8 bit and use a low speed to start and increase it once the bit stops moving around. The high speed will cut a really nice hole. Don't use too much pressure so when it gets through the tire you dont tear up the foams.
HB Ve8 Tekin RX-8/1900kv T8
HB D8
Team Associated B4.1 Tekin RS/Redline 17.5
Team Associated B44.1 Tekin RS pro/Redline 13.5
fazznick is offline   Reply With Quote
Old 05-10-2010, 07:07 PM   #6
this woks great, i have a tendency to forget so this is what i do
"when a man live's dangerous he's not afraid to die, ...... when a man's not afraid to die he live's stangely happy."
bigred0988 is offline   Reply With Quote
Old 05-10-2010, 07:13 PM   #7
Cory Kerber's Avatar
I just heat up a nail with a torch and melt 2 holes in each tire. Don't have to worry about those holes tearing.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 05-10-2010, 07:26 PM   #8
or a fine tipped soldering iron...
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 05-10-2010, 07:38 PM   #9
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
x2 soldering Iron.
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 05-10-2010, 07:43 PM   #10
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Leather punch will still work after you mount them.
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 05-10-2010, 08:55 PM   #11
jammin32j's Avatar
I have heard that too. Does it damage the foams?
VP Pro, Agama
Jeremy Davis
Old 05-10-2010, 09:41 PM   #12
Frank L's Avatar
Trader Rating: 148 (100%+)
Melting it sounds like a good idea. These tires are spinning so fast any little tear ends up a big hole so I don't like cutting them. I usually don't do anything to the tires at all.
Old 05-11-2010, 06:41 AM   #13
johnnyboy's Avatar
Not if you pay attention.
Old 05-11-2010, 09:55 AM   #14
Integra's Avatar
It can if your not careful.......I suggest the soldering iron if your forgot to do it but make sure to not to burn the foam.
Old 05-11-2010, 09:59 AM   #15
I like the soldering iron idea, but I'm not going to use my good one. I can see that rubber creating an issue on the iron tip later on.
If I cut a small "v" using scissor/other, the possibility of tearing it wider is there versus a burned hole.
Drilling holes: In rims or tires? How big? runout_mick Electric Off-Road 7 03-24-2010 10:42 AM
Sand in tires casevac Nitro Off-Road 11 07-07-2009 11:18 PM
holes in the tire or the rims ? SteveJa Nitro Off-Road 16 12-30-2007 09:11 PM
