Old 05-11-2010, 06:10 AM   #16
Slider30250's Avatar
Originally Posted by Bengsch85 View Post
My brother has a Sportwerks .26 V2 in his buggy that had a new p/s put in this spring. He has half a gallon through it and has the tune pretty close to race tune but still on the rich side. We tuned it in 60 degree temps and last night were practicing on the track and after 4 tanks through it the glow plugs started popping on it with the last one the coil actually breaking off in the engine (that ended our night lol). The plugs would come out with a grey coil and dry looking for the most part. Is it possible that since we started the racing with temps in the 60's again and when it started acting up it was in the 40's that it leaned far enough from the air temps to get to lean? or is there something else like an air leak that we should be looking for? And by the way my new buggy with a similiar rich tune did lean out a little but stayed on the rich side of race tune during the same time period. Thanks in advance!
Tuned it 60 degree weather and was still a little rich, after 4 tanks of fuel (most likely this is when the air temps were dropping) it leaned out. Just tune the needles, that will always be free. If your brothers engine runs fine after a re-tune with no popped glow plugs then you found the problem, if it doesn't fix the problem then look elsewhere.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 05-11-2010, 06:13 AM   #17
JarheadRCGuy's Avatar
Send a message via AIM to JarheadRCGuy Send a message via Yahoo to JarheadRCGuy
My vote is on the tune of the motor. Said it ran fine when the temps were in the 60's but then when it dropped to the 40's the plugs started popping. Cooler temps need a richer setting, to compensate for the denser air. That's my vote.
Tango Down Grafix | Tweeked Monkey Racing | Team Terribles
What? You're upset that the track is blown out? Guess what? It's called OFFROAD FOR A REASON!
JarheadRCGuy is offline   Reply With Quote
Old 05-11-2010, 08:05 AM   #18
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
ok if its poping theres to much fuel and your running in 40 degree weather thats cold probubly running to cold of plug and its not burning the fuel up fast enough making the timing of the engine off giving you detnation. try a warmer plug and maybe a extra head shim cause colder more dense air = more fuel . more fuel means more fuel thats gotta burn = hotter plug
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 05-11-2010, 09:48 AM   #19
Default change one variable
try same conditions but jus changing one variable at a time, otherwise, it will be really hard for you to diagnose the problem.
dmakrc is offline   Reply With Quote
Old 05-11-2010, 02:09 PM   #20
Bengsch85's Avatar
We got practice on Thursday with the first race of the season Saturday and both days are set to be in the 60's again so we will see how it reacts to those temps again and go from there. Im really hoping its not a bearing tho cuz they all felt really good when he changed out the p/s a few weeks ago...
D8T/Werks B5~~~~OFNA 9.5/Picco P3 B~~~~TTR ST1/Jammin JPL.28
Savox/Spektrum/Odonnell Fuel
Team Terribles www.teamterribles.com
www.clarkrcpark.com
We are always looking for more racers at the track!
Bengsch85 is offline   Reply With Quote
Old 05-11-2010, 02:35 PM   #21
If you had a bad bearing the idle would be erratic. Just watch the outside temps and richen as necessary.
Old 05-11-2010, 03:09 PM   #22
Pre tune it in your drive way before you go out, you'll know soon enough if it's a bad bearing.
donrod is offline   Reply With Quote
Old 05-11-2010, 03:26 PM   #23
Mr.xb808's Avatar
Default glow plug
New to the nitro scene. I had a glow plug killing problem on 2 motors. I used some 4yr old HPI air filter oil and it must not have been any good because i soaked the filters with it the night before i ran it. The motors screamed and ran perfect for about 4 to 5 tanks and boom started eating glowplugs. Brought them home and took them apart to see what i could find and there it was, carb full of dirt. Track was very dusty and i cant drive and spent alot of time on my lid. One motor was a RB S-5 and the other was a O.S V-Spec. Very costly lesson. Now i check my airfilters after every tank of fuel. Might not be your problem but my V-Spec is DEAD and cleaned the RB up and lucky it is fine.
Mr.xb808 is offline   Reply With Quote
Old 05-15-2010, 06:14 PM   #24
Bengsch85's Avatar
Alright an update for you guys... Ran it today at our open run day and it was great through 3 tanks in the afternoon with temps in the upper 60's and engine temps around 250 the whole time. Now this evening it started in again. As temps fell we richened both the hsn and the lsn close to 3 hrs total and lowered the engine temps all the way down to 200 but its still burning out the glow plugs within a half a tank once the outside air temps drop below 55 or so. Could it be that its too hot of a plug for the air temps? its a Mccoy 59 hot plug.... The only thing that seems to change from running good to bad is the air temp. Any more thoughts?
www.clarkrcpark.com
Old 05-17-2010, 07:55 PM   #25
Bengsch85's Avatar
Anyone?
www.clarkrcpark.com
Eating through glow plugs today? A costly day.. Why? Mpowerz Nitro Off-Road 31 01-05-2008 09:20 PM
HELP! Engine eating glow plugs! foampervert Onroad Nitro Engine Zone 6 07-28-2007 05:23 AM
engine uses more fuel after porting liner ?? mrgsr Onroad Nitro Engine Zone 13 10-18-2005 10:14 AM
engine adjustment questions Greenbox Onroad Nitro Engine Zone 11 05-25-2005 03:05 PM
