Old 05-10-2010, 02:08 PM   #1
Default Braking when rolling and off throttle
I remember seeing on this site or another someone who had the same problem but I can't seem to find the thread. My car seems to be applying a slight break when it's rolling and I'm off the throttle. What could be causing this? Could it be the trim?
The Wedge is offline   Reply With Quote
Old 05-10-2010, 02:11 PM   #2
Bengsch85's Avatar
Most likely cause is the trim but there also could be some sort of binding within the drive train or even that you need to allow a little more space in the linkages between your throttle being at idle and brakes starting to be applied.
D8T/Werks B5~~~~OFNA 9.5/Picco P3 B~~~~TTR ST1/Jammin JPL.28
Savox/Spektrum/Odonnell Fuel
Team Terribles www.teamterribles.com
www.clarkrcpark.com
We are always looking for more racers at the track!
Bengsch85 is offline   Reply With Quote
Old 05-10-2010, 02:23 PM   #3
Thanks I'll start with the trim and work from there.
Old 05-10-2010, 02:27 PM   #4
Bengsch85's Avatar
The easiest way to check if its trim is with the rx off set your throttle servo so that there is no brakes applied and push it. If it still seems to catch somewhere you have a bind other wise its something with your trim. Good luck!
www.clarkrcpark.com
Old 05-10-2010, 07:14 PM   #5
bonghitmike's Avatar
+1
SC8 that will smoke you
-2010 SC8 Shootout- 1st place winner
bonghitmike is offline   Reply With Quote
Old 05-10-2010, 08:01 PM   #6
eurofocus's Avatar
Ya it's most likely the linkage. My new Aftershock has crazy neutral brake drag out of the box... and this is a 'rtr'! And all this was due to the linkage not setup properly.
E-LST2 / sway bar kit (light f/r) / Castle 2200kV / Mamba Monster ESC / 4s / RPM Arms
8e 2.0 / Tekin RX8 / 2050kV / 4s / Hitec 7945
Rally VXL
eurofocus is offline   Reply With Quote
Old 05-10-2010, 08:18 PM   #7
+1! check the linkages...
if you adjust the trim, you might upset the throttle...
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 05-10-2010, 11:34 PM   #8
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
I agree. I would check the linkages first, get it as close to proper as you physically can, and then adjust your trim accordingly.
Are you running a computer-style radio ( buttons and a screen ), or one with knobs( like an RTR radio )? If it's a computerized radio, you may want to reset all your settings before you mess with your linkages( or even easier, delete your current model, or even start a new one ), then adjust the linkages, followed by trimming the radio as your last step.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 05-11-2010, 08:11 AM   #9
I put some springs on my brake linkage because my rear brake was sticking. Now everytime I hit the gas the spring makes sure the brake lever is pushed back.
one8updragracer is offline   Reply With Quote
Old 05-11-2010, 08:19 AM   #10
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
prob brake hang up(drag) if you got any old pens laying around take the springs out and cut them. stick a spring on each screw inbetween your brake pads so theres not draging on you disks... or you can just buy the springs from answerrc but old pens are cheaper lol
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Hong Nor / Jammin Products And RC Fans Thread plazma Malaysian R/C Racers 1717 04-02-2013 01:07 AM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
1/8 scale off-road Electrics adrictan Singapore R/C Racers 6612 06-12-2012 05:02 PM
Off power rolling effect on motor. fatdoggy Electric On-Road 15 05-30-2004 01:29 AM
