Old 05-10-2010, 12:50 AM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default V-spec (speed) backplate wear
so i just bought a used Speed and pulled it apart to inspect.
the back plate had these swirl mards on it as did the base of the con-rod facing the back plate. (PICTURED)
http://i296.photobucket.com/albums/m...uart02/004.jpg
http://i296.photobucket.com/albums/m...rt02/002-2.jpg
Im guessing the conrod and backplate made a light contact at one point. The motor still feels super smooth - no obvious rubbing and no metal pieces or anything like that. Can I still run this backplate/motor? I was thinking maybe theres something wrong with the case for this contact to be possible. Is this a huge problem.
I ask because im about to buy parts on amain and I wanna get an idea of what to buy.
Also the button and piston had alot of black carbon build up - should i try to scrap this off? I already started on the button?
http://i296.photobucket.com/albums/m...uart02/005.jpg
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 05-10-2010, 12:52 AM   #2
wstuart's Avatar
oh and how do you get that metal retaining ring out that holds in the pin that connects the rod and piston? Do I need a special tool? Are those rings reusable?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 05-10-2010, 02:50 AM   #3
Swirl marks on the back plate and the conrod are perfectly normal.
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 05-10-2010, 03:51 AM   #4
underway's Avatar
Trader Rating: 48 (100%+)
Just make sure that you pull the crank as far forward as you can when putting the flywheel on.
underway is offline   Reply With Quote
Old 05-10-2010, 03:51 AM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
All of my speed engines have those marks too.
Old 05-10-2010, 08:46 AM   #6
trevor15308's Avatar
Send a message via Yahoo to trevor15308
ya same here my speed had those marks as well
AGAMA RACING-TKO BEARINGS-AIRTRONICS-SIDEWINDER-WERKS-PROLINE-VP PRO USA-RCrenew.com
trevor15308 is offline   Reply With Quote
Old 05-10-2010, 09:10 AM   #7
Stubbs's Avatar
Trader Rating: 57 (100%+)
Same here on the swirl marks....I have them in my Speed. Not an issue.
The reason your piston and button are black is because that engine was run very rich for a long time. Take some after run oil, or WD-40, and use the soft plastic "wire wheel" on your dremel, and it'll come right off. Just go slow...
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 05-10-2010, 09:11 AM   #8
Racecrafter's Avatar
Trader Rating: 25 (96%+)
That engine is a little more than 2 gallons old.... looks like 8-10 or there was dirt run through it at some point. Also the con rod at the crank pin looks a little rough. (??)
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 05-10-2010, 09:15 AM   #9
smokinu's Avatar
Trader Rating: 60 (98%+)
every used motor has 2 gallons on it jimmy!
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 05-10-2010, 09:31 AM   #10
Stubbs's Avatar
Hey now, the guy I got mine from said it only had one and a half gallons on it!!!
Regardless, clean it up, get the gunk off the piston & button, put a new rod and bearings in it (which you should do on any used motor you buy period), and run the dang thing. OS engines are known for losing pinch quickly, then running awesome on the compression that remains. If it's just too low on power, have it pinched, then run it.
Chances are, if it's that black inside, it was run way rich most of the time, which may not be ideal, but it'll do less harm overall than running it way lean all the time.
Old 05-10-2010, 09:37 AM   #11
Trader Rating: 96 (100%+)
Back plate wear could be an indication of bad bearings. And the black piston...haven't seen that one before. Was it run on veggie oil?
K.Copeland is offline   Reply With Quote
Old 05-10-2010, 10:04 AM   #12
wstuart's Avatar
yeah it was pretty obvious that the engine had more than 2 gallons.
Thanks for the info guys - ill replace the bearings and the conrod for sure.
Do you think I could use the old conrod for breakin and then save the new one for running - ive heard of people doing that. Maybe ill just use a heat gun so t doesnt stress it as much.
Also - this is an old speed with the old style carb. Wll this carb work or should i get a new one? how do i tell if the carb is bad?
thanks so much guys
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 05-10-2010, 10:36 AM   #13
Stubbs's Avatar
thanks so much guys
If there's no obvious wear on the bushing, then go ahead and keep it to use for a break in rod.
My Speed had the old style carb (21H) too. The only improvement I see on the new one (21J) is the location of the idle screw, but it costs way more. I just put new o-rings in the 21H, and used it...
Old 05-10-2010, 11:46 AM   #14
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
The wear on the backplate is completely normal. Almost every engine develops those swirl marks over time. It s more noticeable on the speeds because of the backplate being black annodized.
As for the carbon buildup, it just shows that the engine was run rich for a long time(very common with the speed as people will de-tune them, to limit their power... STUPID!). You can clean it off like stubbs said. If it is not very thick buildup, I would just leave it alone.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-10-2010, 04:28 PM   #15
why the heck would they want to limit it's power? Are they that affraid that they are running it to lean?
I cleaned a p/s and button head up for a guy that was excactly the same. i knew the front bearing was bad and when i changed it out there was layers and layers of dirt baked on the bearing seat.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
O.S Engines thread TTR:EB4 Offroad Nitro Engine Forum 2418 06-29-2017 08:23 AM
This V-spec is driving me insane. Jonro Nitro Off-Road 95 03-30-2009 02:35 PM
