Pinch Question
I think it's funny that so many people are so concerned that they are losing pinch. The reality is, my engine will not run it's best until it's gone.
Now. If you can turn the shaft (without a clutch or flywheel) over with your finger easily with the glo plug installed?? Start worrying
really pinch, is not necesarily a good thing. It's still breaking in.
will your engine run hotter if you still have alittle metal to metal pinch
There are 2 forms of pinch the first is mechanical pinch. This is tested by how hard it is to turn the flywheel over, the second is compression pinch this is noted by the sound the engine makes when coming back down it should make a nice pop sound(varies) the mechanical tightness goes away over time but does not mean that you dont have compression.
Location: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Trader Rating: 23 (100%+)
some pinch
