Old 05-09-2010, 07:27 AM   #1
Default engine sealing
is there any thing else to use to seal your needles besides greenslime
cuppcake80-losi scte-e\tmaxx
cuppcake80 is offline   Reply With Quote
Old 05-09-2010, 09:10 AM   #2
vince7870's Avatar
Trader Rating: 15 (100%+)
Hit up Joe at lucky7rc.com. Get the airseal
Lead, Follow or get out of my way!
vince7870 is offline   Reply With Quote
Old 05-09-2010, 10:22 AM   #3
houston's Avatar
Trader Rating: 91 (100%+)
are you referring to lubing the o rings?
if so then use a synthetic oil product that is safe for orings when reinstalling the needles and lubing the orings
if you are referring to sealing the carb and engine i would recommend the lucky 7 stuff , it is the same as the old air-seal and works as it is intended .
most of your high quality engines have no need for any sealant of any kind , just a tip
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-10-2010, 04:04 PM   #4
thank you appreciate the advice
Old 05-10-2010, 04:42 PM   #5
Kalgard Racing's Avatar
loctite makes a great thread sealant, not loctite for bolts, its a thread sealant. comes in small tube and it is white.
Kalgard Racing is offline   Reply With Quote
Old 05-10-2010, 06:00 PM   #6
if you want to seal threads, just use teflon tape.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-10-2010, 06:11 PM   #7
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Luck7rc.com engine sealant and green slime will do you fine.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 05-10-2010, 07:12 PM   #8
bonghitmike's Avatar
+1
SC8 that will smoke you
-2010 SC8 Shootout- 1st place winner
bonghitmike is offline   Reply With Quote
Old 05-11-2010, 03:47 PM   #9
desmobob's Avatar
Most of your low-quality engines need some serious help.
I had to use Teflon tape AND a liberal application of blue LocTite to keep the needles from spinning out of adjustment from engine vibration on my CEN Racing's Matrix R2 RTR. Feels good to finally have it hold a tune.
Take it easy,
desmobob
desmobob is offline   Reply With Quote
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
Sealing carb and backplate? Twisted Nitro Nitro Off-Road 55 04-07-2010 10:06 AM
Engine sealing. rdsoxfn Nitro Off-Road 27 04-04-2008 07:46 PM
