Old 05-07-2010, 10:05 PM   #1
Fatam's Avatar
Default Starter box help please!!!
I just got a rc8 and a ofna 1/8 starter box. When I push down on the box it won't turn over the buggy. The rubber wheel in the starter box starts to smoke. Why won't it turn my buggy over?
Fatam is offline   Reply With Quote
Old 05-07-2010, 10:12 PM   #2
crotty777's Avatar
if the wheel on the starter box is hitting the flywheel and smoking, I would try pushing the car down harder or heating the engine before trying to start it so it will turn over easier. If its smoking its slipping.
*Dialed RC Hobbies, Windwater RC, Kustom Kolors, HRP, Sweep Racing,
RC Concept*
crotty777 is offline   Reply With Quote
Old 05-07-2010, 10:18 PM   #3
vowbeachbum's Avatar
if u dont have a heat gun use a hair dryer on high.this will work fine.
Team Associated RC8T ce .28 p3 picco 2057 pipe
M11 Spektrum Pro
vowbeachbum is offline   Reply With Quote
Old 05-07-2010, 10:43 PM   #4
neobart's Avatar
Are you positively sure the bump wheel lines up with the flywheel?
Best way to get it right is to take the engine out, and then align it with the pegs.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 05-08-2010, 12:11 PM   #5
toobad4u's Avatar
Trader Rating: 93 (100%+)
If it is a new or real tight motor, you can also try rotating the flywheel back the other wayuntil it gets tight. This will give the starter box a helping hand/ head start on getting the motor turning.
Heating a motor up is one of the easiest ways to help it turn over though.
Following to be used in a pinch, but not really recommended. If you do not have a way to heat it up, you can also try loosening the glow plug just a bit. This will lower the compression and usually makes it easier to turn over also. Just be sure to tighten it back up after you get it fired up, and before you start running it around on the ground.
Mihabi RC Your Hometown Hobby Shop.
(850) 914-2815
toobad4u is offline   Reply With Quote
Old 05-08-2010, 04:18 PM   #6
make sure u didnt flood the motor, then u will never turn it over, but if its a new motor always heat it up to at least a gallon went through it
skidoos is offline   Reply With Quote
Old 05-13-2010, 11:23 PM   #7
Fatam's Avatar
I got it. It was a hair off line and the bump was rubbing and melting. After adjusting the top of the box it now works great.
Starter box help! Ducati998 Nitro On-Road 7 05-22-2004 07:06 PM
Need help on starter BOX! Yokomo_King Nitro On-Road 6 11-18-2002 01:39 PM
