Old 05-07-2010, 06:58 PM   #1
English365's Avatar
Trader Rating: 128 (100%+)
Default will the d8t diff housing fit the d8
Hey guys, my D8 the front diff housing is stripped out, now my track only has the d8t diff husing. Now i dont have time to get a new one from amain, and im racing tomorrow. I need to know if the D8T front diff housing part number 8000-2 will fit the D8 which is part number 8000-1? Im figuring it will fit with no problems but not 100% sure, so im asking yall!!!
Dustin
Kyosho America~Thunder Power~Team Orion~KO PROPO~AKA
Mikes Hobby Shop...TeamTreeTop!
English365 is offline   Reply With Quote
Old 05-07-2010, 07:05 PM   #2
willbe's Avatar
they are the same.
Only one that is different is the center mounts as they have the extra spacers for the D8T
HB D812, HB D8T, HB D812E, HB D413, HPI Blitz SC, Losi 22 & 22T
Special Thanks to:
HotBodies/HPI Racing, Upgrade RC, OS Speed, Sidewinder Fuels, Hitec
Proudly using: Spektrum DX4R, Viper-RC Electronics, Reedy Batteries, & Pro-Line
Cancer Sucks
willbe is offline   Reply With Quote
Old 05-07-2010, 07:45 PM   #3
trevor15308's Avatar
Send a message via Yahoo to trevor15308
yes it will fit
AGAMA RACING-TKO BEARINGS-AIRTRONICS-SIDEWINDER-WERKS-PROLINE-VP PRO USA-RCrenew.com
trevor15308 is offline   Reply With Quote
Old 05-07-2010, 08:50 PM   #4
English365's Avatar
SWEET no i cant wait to run, i appriceate yall!! yall never let me down
Old 05-07-2010, 09:16 PM   #5
good luck tommorw
Old 05-07-2010, 09:24 PM   #6
English365's Avatar
Thanks man!! i appreciate your help guys and appreciate the words!! Good luck to you to if you running tommorow
Old 05-07-2010, 09:32 PM   #7
fattyalan's Avatar
my pinion gear ( i think thats what it is called) on the front is also touching the diff case...is it a usual for the d8's?
Hot Bodies D8
O.S V-spec EB mods
Spektrum DX3R
Nitro-X Fuel
fattyalan is offline   Reply With Quote
Old 05-07-2010, 11:00 PM   #8
It should not be touching the diff case. The input gear may need to be reshimmed. How many shims to do you have between the input gear and the bearing? It could also be too much slack on the input gear when you attached the center drive shaft. Make sure to push the gear as much as you can toward the center drive shaft and make sure the drive shaft is as far onto the input gear as possible.
Also, you may need to adjust the number of shims on the diff itself to compensate.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 05-08-2010, 09:23 AM   #9
English365's Avatar
Yeah man my problem is the front hinge pin holder the screw goes through that strips out, and thge hinge pin comes out and the arm sags! Now your problem is just shmming, as long as the ring and pinion in there are acutaul hb D8 ones you shopuldnt have a problem just reshim them and drive, but I wouldnt reck ammend driving with it rubbing
Dustin
