Your input on the problem?
I just recently bought a used traxxas Nitro evader from a friend. It has a new engine with new piston and sleeve. When i first tried getting the engine running, there was fuel everywhere and it seemed to be leaking from the carborator. The first thought was there was a bad o ring in the carb, but that was replaced. The fuel leaking has stopped, but the engine still wont stay running. my hobby store is now saying that i need a new engine. Are they just trying to make more money off of me or what? brand new piston, and sleeve. new o rings in the carb. does anyone have any ideas? I really dont think i need a new engine.
well, i trust my friend that the engine is new, because the HS also said that it seemed to be new. I guess im just asking about other problems it could be. I am new to nitro engines but it seems like there could be plenty else wrong. I trust my store, but so for 3 different techs have looked at it, and come up with 3 different problems. First the carb needed a new o ring, then it was the piston and sleeve, now i need a whole new engine. Ive seen the car run, it just doesnt stay running: which would be a problem.
the engine has not been broken in yet. right before i recieved the car, the new engine was put on and given to me so i could start again fresh. just need to get it running long enough so it can be tuned and broken in.
Oh read the breakin bible at the top of the thread........theres one for tuning and breaking in. plenty of vids on utube.
Heat it up with a heat gun first .....
so this is back to my original question, my hobby shop is telling me i need a new engine. Should i try and get it working on my own before investing another 100 bucks?
Yes.
ok, thanks for the help guys.
Oh well if your breaking in the new piston/sleeve and have gone back to factory needle settings then yeah its probably sloppy rich and won't idle. May need to lean out the LSN to get it to idle.
My money is on the exhaust gasket.
but it could be something as simple as the exhaust gasket. If you are running at factory settings i have actually had it so rich that when i pick up the car or move it, oil and fuel would come flooding out the end of my exhaust pipe. And of course i thought i had a leak.
If it is not these things, then my next guess is the front bearing.
