Old 08-10-2010, 05:02 PM   #16
mr240's Avatar
Trader Rating: 61 (100%+)
Sounds like you have a brand new engine. You need to heat the engine block with a heat gun or blowdryer to about 150-180 degrees. Your engine will turnover alot easier.
mr240 is offline   Reply With Quote
Old 08-10-2010, 05:10 PM   #17
tq_racing's Avatar
Trader Rating: 65 (97%+)
Send a message via AIM to tq_racing Send a message via Skype™ to tq_racing
Originally Posted by pyromania View Post
Is the engine brand new or was it recently pinched?
If so you are encountering something called mechanical pinch. You will need a heat gun (a hair dryer is not strong enough) to heat that sucker up too at least 220-230 degrees. That will help start the engine and begin the break-in process.
http://www.rctech.net/forum/nitro-of...eak-bible.html
i bought it used. the guy was in the middle of the break in process. i well try this and if it doesnt work ill let you know. thank you
Jason Littlejohn
JL GRAPHICS for all your paint & vinyl needs!!
www.facebook.com/jl.graphics1
tq_racing is offline   Reply With Quote
Old 08-10-2010, 05:43 PM   #18
tdr170's Avatar
Default Cluth Help
Heat the engine as decribed with a heat gun 180-200 deg should be enough.
Also make sure the engine has some lube in it in other words not dry after run oil, Marvels or any two stroke oil will work. (just a few drops)
When you try to start it loosen the plug so as to produce blow by this will help decrease compression once it starts re-tighten the plug.
You should also check your head gaskets as they also space the head from the piston Nova motors usually have .70mm of Gaskets/Shims.
If you have never broke a motor in do yourself a favor and do some research online there is alot of good info and several different methods.
Hope all works out for you!
tdr170 is offline   Reply With Quote
Old 08-11-2010, 12:47 AM   #19
tq_racing's Avatar
went and got myself a heat gun and heated the shi* out of about 250* and it started. so glad it did.
now my next problem is when i go to set it on the ground it shuts off...what could be doing that?
oh and i have broken in other motors 5 i think. but they were done the old way of idel like 2 tanks then slow run another tank. but my last motor i did the new way.
Jason Littlejohn
centax clutch ? HELP ! carpet_killa Nitro On-Road 60 10-13-2011 05:38 PM
werks clutch HELP!!!! mamba4life Nitro Off-Road 37 05-01-2009 07:20 PM
Clutch Help ? tdr170 Nitro On-Road 16 02-22-2009 07:48 PM
8ight clutch help I think pvtysux Electric Off-Road 10 04-08-2007 03:07 PM
centax 2 clutch help!!! nitro08 Nitro On-Road 10 03-15-2007 04:47 PM
