Old 05-05-2010, 09:19 PM   #1
RC8daBOMB's Avatar
Post Shed Weight RC8
Hey everyone i have a question:
I have been using my RC8 for about 3 months now, and when i put it on the sccale it says 9.2lbs O.o How do i shed some weight on my RC8 (that rhymes). Thanks to anyone who helps!
-Erik
22SCT / Reedy Sonic 17.5 / Ace 1015
22 / Tekin 13.5 / Spektrum Low Profile
MBX6 (probably going to convert to 4x4 SC) / Something / Something else
RC8daBOMB is offline   Reply With Quote
Old 05-06-2010, 07:15 AM   #2
Slider30250's Avatar
What scale are you using to weigh it, because bathroom scales are often times not accurate.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 05-06-2010, 07:58 AM   #3
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
-Erik
Get a RC8B its only 7.4-7.8 lbs.
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 05-06-2010, 08:16 AM   #4
gholt13's Avatar
is that with or without tire i have two and they both weigh around 8.2lbs
RC8B/RC8TLE/
gholt13 is offline   Reply With Quote
Old 05-06-2010, 10:00 AM   #5
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
yeah, I was gonna say mine is 8.0lbs on the dot. race ready as well...
-DC-
smitty2802 is offline   Reply With Quote
Old 05-06-2010, 10:18 AM   #6
Mine is 7.8 race ready but with an empty tank.
Old 05-06-2010, 10:20 AM   #7
oh mine was with basically a full tank... id like to know what the differences are in engine weight.
-DC-
Old 05-06-2010, 10:25 AM   #8
pfunk66's Avatar
Came across this a while back...
http://www.tarzee.com/rcdb/buggies.php
AE SC10 FT - TLR 22
VP-Pro USA - Team Upgrade RC - PFunk Designs
Clinton County RC Raceway CCRCR.net
pfunk66 is offline   Reply With Quote
Old 05-06-2010, 10:39 AM   #9
-DC-
Here is whats on my buggy:
Stock RC8B kit
BCE chassis with different cut outs
Aluminum AE knuckles & AE hubs
Werks B5 w/2057 pipe
Reedy lipo pack
Airtronics micro receiver
Old 05-06-2010, 10:46 AM   #10
Here is what I have done. Mine is down to just over 3400g. Body, AKA Tires, and Empty Tank... As measured at JBRL...
Titanium Screws : 4x12s on steering posts and radio tray/front battery box attachment (I would replace the ones that mount the bulkheads and radio tray to the bottom, but Ti strips out and the heads get messed up easily if mounted on the bottom. The solution for using Ti on the bottom screws is to have the chassis holes countersunk 1/2 mm deeper so the screws sit up in, rather the flush with the bottom of the chassis)
Aluminum Outdrives: They haven't wore that badly yet http://www.amainhobbies.com/product_...eshaft-Axles-4
LiFe battery/ KO 407s receiver
All Servo mounting screws, and any non weight supporting screws have been replaced with aluminum ones. The 2 screws that join the bulkheads below the shock tower. The ones that hold the sway bar attachment on the bulkhead. All the Shocktower mounting ones to the bulkhead. (You get the idea) Also all the M3 nuts and M4 that screw on the shock tops are Alum. http://www.fastener-express.com/AluminumScrews.html
Ti - Shock Pins on A-Arms (Lunsford) http://www.amainhobbies.com/product_...k-Mount-Pins-4
Ti - Upper Hinge Pins on front arms, can't use the other ones as the outers bend easy, easier then the steel ones, and the newer inner ones are bigger and bead easily, has some tops laying around (Lunsford) http://www.amainhobbies.com/product_...-Hinge-Pin-Kit
Alum Steering Posts: King Headz, but these sheared on the first outing so back with the steel http://www.amainhobbies.com/product_...r-Posts-1-pair
Plastic Chassis Braces
Turnbuckles: Ti all around
I think there might be a bit more, but thats all I can remember.
Future Mods:
BCE Chassis
Ti screws for bottom side
Graphite (B) Towers when I can get the PSM ones.
I think with those mods I'd start to be underweight, so would stop there.
Tekno NB48 Samurai Proline Tires
Tekno NT48 XZB Speed Proline Tires
Tekno EB48.3 Viper Proline Tires
Tekno / Dialed RC Hobbies / TKO Competition Development /
Stirex is offline   Reply With Quote
Old 05-06-2010, 10:46 AM   #11
Panic09's Avatar
is this accurate? says the Odonell buggy is 2720grams including racing gear?
"I was so far behind I thought I was first"
MIKES RC WORLD(r.i.p) | TACOMA RC RACEWAY | FOUR SEASONS RC RACEWAY(r.i.p) | ISLAND RACEWAY
Panic09 is offline   Reply With Quote
Old 05-06-2010, 10:50 AM   #12
wallot's Avatar
it is not as stock D8 does not have 3400g RTR. my lightweight D8 has 3400g with no fuel and stock used to be over 3600g
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 05-06-2010, 11:05 AM   #13
Panic09's Avatar
my MBX6 is 3304 gram , except fuel. and i can probably shave off another 15 grams if i use AKA tires.
Old 05-06-2010, 01:14 PM   #14
Stock RC8B kit
Reedy lipo pack
well we have the same engine setup then...lol
b5/2013
box stock car-plastic rear hubs
not running lipo
micro receiver
sent you a PM Joey
Thanks,
-DC-
Old 05-06-2010, 07:52 PM   #15
plus2ss's Avatar
Servos play a big part in weight saving. The ACE/XP servos wheigh alot more than others like the Orion/Savox servos.
plus2ss is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
:::::Hyper ST Electric Conversion::::: Hyper ST-E Guy Electric Off-Road 12 11-11-2010 03:41 PM
Novarossi 367 trouble Luc252 Nitro Off-Road 92 05-01-2009 11:41 AM
What Will a Factory Electric 1/8th Look Like? Edumakated Electric Off-Road 15 04-16-2008 08:39 AM
Tags
rc8, shed, weight
