Old 05-04-2010, 05:47 PM   #1
Default How to measure my fuel tank?
Hi guys... at the end of the month we have national truggy race which have rules..
At the truggy the only rule that scares me is that the fuel tank must be 155ml with all the fuel lines and fuel filters...
I know that the ST-RR fuel tank ise 150ml but how can i measure all the fuel lines and my fuel filter?
i have 36cm fuel line and this fuel filter http://www.amainhobbies.com/product_...ty-Fuel-Filter
TEAM: http://www.offroadersonly.gr/
Kyosho Inferno ST-RR,Novarossi Plus 4T,Byron Fuels,Sanwa M11,Hitec 7954HV/ACE DS1313
DE Racing,Answer-RC,Ascendancy,TKO,Pro-Line,Fioroni,King Headz,K Factory,Protek,O'Donnell
the_winner is offline   Reply With Quote
Old 05-04-2010, 05:53 PM   #2
Suspended
Trader Rating: 41 (100%+)
Fill your tank. Pull fuel line from carb. Now blow through until fuel (or whatever you filled it with) comes out and plug it with your finger. Top your tank off. Now blow through and catch ALL the "fuel" into measuring device (some fuel bottles have markings or measuring cup) and measure it.
Puppies! Flowers <3
Cadimman is offline   Reply With Quote
Old 05-04-2010, 05:57 PM   #3
Jon Moore's Avatar
Any medical supply store will have what you need to measure your fuel using Cadimman's method. (like a beaker)
Jon Moore is offline   Reply With Quote
Old 05-04-2010, 06:03 PM   #4
thanks but you told me how to see how much .ml is my tank... my tank is 150ml ..
maybe you forgot something.
1. full the tank with liquid.
2. blow the fuel until it reach the carb
3. refill the tank
4. blew the fuel from fuel lines into the meter and also the fuel inside of the tank at the meter
is this correct?
Old 05-04-2010, 06:31 PM   #5
mudboger07's Avatar
He told you correctly, You need ot make sure your fuel line, filter and tank are full of fuel, then blow threw the pressure line while holding the carb line into a measuring cup that shows mills. When done it should read 150ml.
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 05-04-2010, 06:35 PM   #6
Suspended
3. refill the tank
is this correct?
Correct.
Puppies! Flowers <3
Old 05-04-2010, 06:37 PM   #7
i know already that my tank is 150ml
but how much is with the fuel line and fuel filter?? it must not be up of 155ml
my question is how i can see that the 36cm fuel line and my fuel filter have 5ml of fuel,,
sorry for my bad english.but i dont want to know how much is my fuel tank...the fuel tanks is 150ml
the rules said that the fuel tank with the fuel line and fuel filter it must be 155ml of fuel...
Old 05-04-2010, 06:38 PM   #8
toobad4u's Avatar
Trader Rating: 93 (100%+)
FWIW, The guy this past weekend doing the measuring at the RC Pro series said 1 inch of fuel tubing is approx. 1ml/cc of fuel. A large fuel filter is around 4-6 ml/cc.
Stephen
Mihabi RC Your Hometown Hobby Shop.
(850) 914-2815
toobad4u is offline   Reply With Quote
Old 05-04-2010, 06:41 PM   #9
Originally Posted by toobad4u View Post
Yep, once you have all the fuel lines full of fuel, blow through the hose that attaches to your pipe, while holding the line that goes to the carb in the measuring device. (beaker or graduated cylinder) Be sure to push down on the rear suspension to get all the fuel out of the tank at the pickup. Read the side, and you have your measurement.
FWIW, They say a large filter is around 4-6 ml/cc.
Stephen
thanks Stephen... i think that i must put a very small fuel filter because this is big...
Old 05-04-2010, 06:46 PM   #10
Frank L's Avatar
Trader Rating: 148 (100%+)
I purchased a graduated cylinder on amazon.com to measure mine. That's what they use atthe big races plus it's extreemly accurate. It was around 10-15 bucks.
Old 05-04-2010, 06:49 PM   #11
toobad4u's Avatar
Are you assuming that the tank it 150ml because that is what the book says, or have you actually measured it?
Stephen
Sorry, I changed my reply from earlier, after I posted it, but you had already quoted it. I saw someone else had already replied with the same answer. LOL
(850) 914-2815
Old 05-04-2010, 06:54 PM   #12
toobad4u's Avatar
If you are over, and can't cut out some fuel line, you can take an extra piece of fuel hose and put a bolt or screw in each end to seal it up and drop it in your fuel tank to take up space.
Stephen
(850) 914-2815
Old 05-04-2010, 07:41 PM   #13
rc skyline's Avatar
You have to measure your tank and lines/ filter as one as the guys have told you to do.
If you do it any other way it will not be acurate
I highly doubt your tank will be exactly 150ml
Also when you blow the fuel thru be sure to blow hard at the end to get the last bit of fuel thru from the filter stone.. wait a few seconds and blow again
Dave
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Old 05-04-2010, 08:32 PM   #14
Frank L's Avatar
Trust me the tank is not 150cc. 140-145 maybe but 140 is closer the actual tank volume.
Old 05-04-2010, 11:13 PM   #15
+1 Manufacturers leave room for fuel tube & filters so tanks are normally under the 150cc.
Any event claiming they will check fuel capacity must make the test equipment available so you can check what you running.
Bren Ralls is offline   Reply With Quote
Best Fuel Gun? jeff1 Nitro On-Road 66 06-03-2014 07:30 AM
my V-Spec blew up Nik Nitro Off-Road 65 03-11-2008 01:45 PM
How much amps (continuous & peak) will a brushless system draw? HPI RS4 Electric On-Road 36 11-24-2007 01:52 PM
What is the best way to break in a new ening? adsl Onroad Nitro Engine Zone 27 02-10-2005 07:49 AM
