Need help with my Kyosho DBX
Hello, so im kinda new here, and i wanted to ask a simple (maybe not so simple for some people) And that is that my engine won't take the fuel from the gas tank... i have everything wired up right, but it just wont get fuel.. i tried to direct inect some fual, and it started on first try..
Can any1 Help me with this? Thx.. I appreciate it !
Noone that can help me?
Need more info. Are you priming it first by holding your thumb over the exhaust and pulling the rope a few times? if you left fuel in it then it might be clogged by oil. in this case remove the air cleaner, block the carb with your finger and pull the rope a few times. once the fuel starts flowing it should clean itself out, in my experience anyway.
I've done that
I've tried everything, even tried to clean the gas tank inside and outside... Priming won't work either.. something i did wrong ?
Once it starts does it keep running? Are your needles all the way closed or too lean (go back to factory), or maybe a hole in the gas line?
ad
Have tried to check for holes. when i do direct injection, it starts running, but the gas ain't coming in the motor from the tank. the pin is almost screwed out !.. Its so high, and still no Nitro Fuel...
Take the needles out and blow some fuel or air through there, maybe something is clogging it up. After thatI am out of ideas?
YES !
I finally started it.. just need a new ran to supply the wheels with power.. i span ut all the tags on it :/
EZ starting
I pull the air filter off, pull the throttle , drop in 4 drops of fuel into the carb. Pull a few times should start.
