Old 05-04-2010, 12:22 PM   #1
Trader Rating: 90 (99%+)
Smile 10 MIN ON ONE TANK? RC8T
Is it possible to get at least 10 Min on one tank of fuel in an RC8t Champ Ed, with an OS V-Spec Limited Ed, all stock configuration....
wickedracer is offline   Reply With Quote
Old 05-04-2010, 12:25 PM   #2
Shoaf85's Avatar
Trader Rating: 19 (100%+)
Usually easier to get 10 minutes on a truggy than a buggy because of the larger tank. You should be able to pull it off if you have a good tune and don't drive really really hard!
Team AE all the way...
FASTLANE GRAPHIX !!!!!!!!
Shoaf85 is offline   Reply With Quote
Old 05-04-2010, 12:26 PM   #3
JarheadRCGuy's Avatar
Send a message via AIM to JarheadRCGuy Send a message via Yahoo to JarheadRCGuy
Quite possibly...if you pray to the fuel gods and don't touch the throttle!
Tango Down Grafix | Tweeked Monkey Racing | Team Terribles
What? You're upset that the track is blown out? Guess what? It's called OFFROAD FOR A REASON!
JarheadRCGuy is offline   Reply With Quote
Old 05-04-2010, 12:28 PM   #4
Default i get 10min
Full out on the throttle i get 10min ...depends on the tank size too. Im running 30% nitro + cold plug.
dmakrc is offline   Reply With Quote
Old 05-04-2010, 12:29 PM   #5
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Very easy! There are many factors that determine runtime. Two main things besides your engine/fuel/pipe/plug/venturi setup are the driver behind the wheel(throttle tendencies) and the track you are running on. Obviously a heavy trigger finger will burn more fuel, and a larger track will generally burn more fuel. The weather(temperature/humidity, even altitude) will also play a factor in runtime. So to answer your original question, yes 10+ minute runtime can be had in most cases.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-04-2010, 04:24 PM   #6
Talking thanks
Thanks for all the replies fellas....just needed to know!!!
Old 05-04-2010, 04:46 PM   #7
losi_racer's Avatar
Trader Rating: 25 (100%+)
ACTUALLY buggy gets better gas mileage, the truggy is heavier and gets less mileage
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-04-2010, 05:04 PM   #8
Na bro. That's not how it works. Truggy tank has 25 more cc's. Truggies almost always get better fuel mileage because of that. Even with the heavier load and bigger tires. Obviously you can get away with pulling on the throttle more with a truggy, so if you're doing that, the above may not be the case. If you drive the truggy smoothly like a buggy, the above will be true.
-Koby Kubrin-
Old 05-08-2010, 01:58 PM   #9
primo86gt's Avatar
Easy with the right pipe.. 14+ with the restrictor out of the tank. V -spec, P3 plug, tsais t32 pipe ( may not be legal at roar events ) 240-245 deg,
http://www.tsais.com/products/exhaus...oad/index.html
John Moretti Serpent SRX2 & SRX2 SC, Hobbywing / Revtech,
D3.5, D4 whatever it takes, RC8Tce FOR SALE or Trade
TheRangeplantcity.com
AS LONG AS YOUR HAVING FUN WHAT DOES IT MATTER
primo86gt is offline   Reply With Quote
Old 05-08-2010, 02:25 PM   #10
+1
I have a stock D8T only an aluminum servo arm and I just recently made it past 10 minutes in a 20 minute main with one pit. I was running a GO5port turbo 8mm stock venturi and a 2047 GO pipe and 30% fuel..
RICK ENDLER
Hot Bodies Racing
www.greathobbies.com
SKY RC
Exotek
endler is offline   Reply With Quote
Old 05-08-2010, 03:10 PM   #11
losi_racer's Avatar
nvr been the case for me but what ever
Old 05-08-2010, 07:30 PM   #12
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
wow i get around 13-14 in my d8t with my ebmods js race prep. and i get around 10-10 half in d8 buggy with full mod.....
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 05-08-2010, 07:36 PM   #13
Strange. Well if you drive your truggy really hard, you won't get the mileage. If you drive it like your buggy(at least relatively) you will get better run time in the truggy. 13-14 minutes isn't too big of a challenge in a truggy. Might be a stretch in a buggy.
-Koby Kubrin-
Old 05-08-2010, 08:01 PM   #14
Frank L's Avatar
Trader Rating: 148 (100%+)
So you guys that are getting 13-14 min per tank of gas you are saying in a 39 min race you pit 2x. Or every 11-12 mins? Of do you pit like the rest of us around 8-9 and pit 3x in a 30 min race.
Old 05-08-2010, 08:17 PM   #15
primo86gt's Avatar
Every 10min. If you end up wheels up with a low tank youll probably flame out, unless you have a clunker in your tank.. ( weighted pickup )
